It is currently Jun Thu 04, 2020 12:35 pm
 Post subject: Strange Pilot Light
PostPosted: Sep Tue 30, 2008 9:57 pm
Guys, I have the blown-out pilot light out of my 1949 Zenith 7H920, and can't find a replacement locally. It's shaped just like a regular Christmas light, but has a double contact bayonet base. It is a 115-125 Volt 10 watt.
Can somebody supply me with a link to the light-bulb express online!!
Steve McDonald
PostPosted: Sep Tue 30, 2008 10:49 pm
Look in your local hardware store or home center for an appliance lamp. There should be a couple different wattages with that base configuration.
Tom Lager
My web page http://lagert.undrground.org
PostPosted: Sep Tue 30, 2008 10:52 pm
The Dollar stores should have a pack of four in either 4 or 7W...
PostPosted: Sep Tue 30, 2008 11:02 pm
Silent Key
That was also a popular sewing machine lamp, but if you buy it from a sewing machine place, expect to pay a lot more. If you have the choice of wattages, I would go with the lower wattage, as some of them run pretty warm and the heat discolors the cabinet and dial.
Curt
Curt, N7AH
PostPosted: Oct Wed 01, 2008 2:43 am
Location: Warren, MI, USA 48093-6744 N42.50973 W83.02633
Those are going to be (most likely) a candleabra base.
This bulb was commonly used in sewing machines, as Curt said, but the most common of that type was a tubular 15 watt variety, rather than the 10C7/DCB style you're talking about. You should be able to get one from a nearby discount store (Wal*Mart and Target are two that come to mind quickly), as well as many large grocery stores.
If you can fit a 15 watt tubular sewing machine bulb (which should be the easiest to find) - I think it's a 15T6/DCB, and it runs too hot, put a 1N4004-1N4007 diode in series with it and it will run cooler and last longer.
Those kind of bulbs were also sometimes used in exit signs.
The mind is like a parachute - just because you lost yours doesn't mean you can borrow mine.
PostPosted: Oct Wed 01, 2008 2:49 am
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
Yep you're right about that... Gotta learn to read...
PostPosted: Oct Wed 01, 2008 4:08 am
Location: Iron River Wi. 54847 (jukeboxdenny@yahoo.com)
Hi- I have used these from Grainger's, 6 watt @ 130 volt.
there part number is 4V756.
http://www.grainger.com/Grainger/items/4V756
they also have it in a 120 volt version,
http://www.grainger.com/Grainger/items/4V754
I used the 130 volt lamp in one of my zenith am/fm table top sets (1948- 7H820 )), has not melted anything yet, and not too bright :D
Dennis.
"Multi-Horn Hi- Fidelity" By AMI
Post New Topic Post Reply  [ 7 posts ]  Moderator: sofaslug
Users browsing this forum: Eddy and 18 guests
