| Author |
hunter2115
Post subject: Getting decals on straight Posted: Oct Thu 25, 2012 1:19 am |
| Member |
Joined: Dec Thu 29, 2011 7:45 pm Posts: 1762 Location: York, PA
I recently had to get five individual repro decals on the control board of a RCA 19K console. Problem was getting them on straight. Since I am staying with the original lacquer, I didnt want to use any sort of masking tape as even the blue stuff tend to pull up old finish. I didnt want to mark a line with a pencil either since it might show up later as an indentation in the finish or the wood itself. What I did was to use a row of 2 x 2" Post-It notes. Starting straight along the left edge of the control board, I affixed the first note. then simply butted the next one beside the first, carefully lining up the edges of the notes. Once I got the whole way across the control board, I double checked for straightness with a scale. The notes also provide a nice surface to mark where each decal should go horizontally as well. Then it was a simple matter of applying the decals, aligning each one with the bottom of the notes. Once all decals are applied, the Post-It notes come off easily- leaving no residue and no damaged finish. Works great!!
_________________ Bill W
| Top |
Chuck Schwark
Post subject: Re: Getting decals on straight Posted: Oct Thu 25, 2012 1:18 pm |
| Moderator |
Joined: Jan Thu 01, 1970 12:00 am Posts: 3465 Location: Evanston, IL
Another great tip. Thanks for posting your procedure. Chuck
_________________ Chuck Schwark,
The Philco Repair Bench
Schematic Photocopy Service
www.philcorepairbench.com
| Top |
Rosin Sniffer
Post subject: Re: Getting decals on straight Posted: Oct Thu 25, 2012 1:44 pm |
| Member |
Joined: Feb Fri 24, 2012 3:16 am Posts: 825 Location: Kenai, Alaska
Wonderful idea. Thanks. Now I need a way to stop the tremor in my hands. No coffee for a week?
_________________ The trouble with trouble is that it usually starts out like fun.
| Top |
Philco Fan
Post subject: Re: Getting decals on straight Posted: Oct Fri 26, 2012 9:12 pm |
Stiff shot or 2 of brandy outta settle you down,or cause you to put the labels on you hand! What did you do about the original labels? Phil
_________________ I've been doing so much for so long with so little I can now do anything with nothing!
| Top |
hunter2115
Post subject: Re: Getting decals on straight Posted: Oct Fri 26, 2012 9:24 pm |
| Member |
The originals were very dark and thin. They basically wore off with a little scrubbing with 0000 steel wool while applying some Howards restore a finish. I just kept at it until they were gone.
| Top |
Rosin Sniffer
Post subject: Re: Getting decals on straight Posted: Oct Sat 27, 2012 12:04 am |
| Member |
Phil, do you think Glenlivet would have the same tranquilizing effect?
Hunter, sure wish you had had your inspiration earlier while I was finishing this American Bosch. I had 10 decals to start with, used them all and still ended up a bit of a bubble off level and off center. Next job I do, I will use sticky notes for both dimensions.
| Attachments: |
| Top |
hunter2115
Post subject: Re: Getting decals on straight Posted: Oct Sat 27, 2012 12:35 am |
| Member |
Doesnt look bad though. At first glance, slightly out of place decals dont catch the eye-except of the installer! I wonder how many were off from the factory? And, the notes only help as a guide, you still have to get them on right. I went thru a few myself! I just try to eliminate variables that can go wrong on tough stuff.
| Top |
Philco Fan
Post subject: Re: Getting decals on straight Posted: Oct Sat 27, 2012 2:02 am |
I don't know what Glenlivet is as I don't drink but would you mind leaving the room for a minute? I need those knobs  . Very nice set and who's lookin' at the label? Phil
| Top |
Rosin Sniffer
Post subject: Re: Getting decals on straight Posted: Oct Sat 27, 2012 3:22 pm |
| Member |
Phil, your comment on the knobs makes me feel good. I refinished them too and used Tamiya Color Gold Leaf X-12 that I found at a hobby shop for the rings. It was applied very sparingly with a toothpick.
| Top |
philsoldradios
Post subject: Re: Getting decals on straight Posted: Jan Sat 05, 2013 3:35 am |
| Member |
| Top |
Rosin Sniffer
Post subject: Re: Getting decals on straight Posted: Jan Thu 10, 2013 12:52 am |
| Member |
Hunter,
Your Post It Notes tip saved me a lot of grief. Not only was I able to get the decal on center and level, I used the stickys to align the black striping. Fearful of bleed under with masking tape, I decided to use Pactra model striping tape rather than paint. Thanks much for the tip.
Dick
| Attachments: |
| Top |
hunter2115
Post subject: Re: Getting decals on straight Posted: Jan Fri 11, 2013 2:41 am |
| Member |
Dick That cabinet looks great! Glad you found the post-it note tip useful. Im thinking about trying them as masking when touching up trim- use the note's adhesive against an old finish and tape regular masking onto the loose end of the note. The post-it note adhesive doesnt seem to have the tendancy to pull up old finish like the blue masking tape. I wonder how it would work with lacquer?? Hmmmmm
| Top |
Rosin Sniffer
Post subject: Re: Getting decals on straight Posted: Jan Fri 11, 2013 3:45 am |
| Member |
Bill,
There were about 4 coats of Deft semi gloss laquer on the cabinet that had dried for 24 hours when I put on the striping and decal. No lacquer was lifted or any adhesive visible when I pulled off the post-its. Since then it has received another 4 coats and there is no lacquer adhesion problem.
Dick
| Top |
Avery
Post subject: Re: Getting decals on straight Posted: Jan Fri 11, 2013 1:54 pm |
Joined: Jan Thu 01, 1970 12:00 am Posts: 2504 Location: Potomac, MD 20854
This is a great tip.
The pads also come in a 5" width (maybe even wider), which makes the job even easier.
_________________ Avery W3AVE
| Top |
BigBandsMan
Post subject: Re: Getting decals on straight Posted: Jan Fri 11, 2013 2:07 pm |
| Silent Key |
Joined: Jan Thu 01, 1970 12:00 am Posts: 5813 Location: Raleigh NC USA
Excellent tip, Bill. Been awhile since I had to do any decal work, but be assured that I'll remember this trick when the time comes again! Many thanks and best regards,  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
hunter2115
Post subject: Re: Getting decals on straight Posted: Jan Fri 11, 2013 2:33 pm |
| Member |
Ill have to look for those 5" ones. Might be good for masking.
| Top |
Avery
Post subject: Re: Getting decals on straight Posted: Jan Fri 11, 2013 2:36 pm |
hunter2115 wrote: Ill have to look for those 5" ones. Might be good for masking. I assume Staples/Office Depot/etc. sell them, but if you can't find them, let me know and I'll send some. You deserve it for this tip.
| Top |
hunter2115
Post subject: Re: Getting decals on straight Posted: Jan Fri 11, 2013 2:57 pm |
| Member |
Phil That Admiral TV project came out great! Ive often thought about trying a TV, but they sure look like a lot of work. Probably helps to know what youre doing too-so that leaves me out! Maybe someday...
| Top |
Nick D.
Post subject: Re: Getting decals on straight Posted: Jan Fri 18, 2013 9:56 pm |
| Member |
Joined: Jun Wed 01, 2011 8:05 am Posts: 7094 Location: "Amish Country", PA
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
Avery
Post subject: Re: Getting decals on straight Posted: Jan Fri 18, 2013 10:23 pm |
Hi-tech solution to a lo-tech problem.
| Top |
Users browsing this forum: No registered users and 1 guest |
