It is currently Jun Mon 21, 2021 6:19 pm
 Post subject: Is there a better way to fix worn out remote controls?
PostPosted: Sep Tue 08, 2015 12:46 am
I cut small squares of 3M copper tape, and stuck on the worn out buttons.
Seems to work pretty good so far on the in-law's TV remote.
Any other ideas that work well out there?
 Post subject: Re: Is there a better way to fix worn out remote controls?
PostPosted: Sep Tue 08, 2015 1:55 am
I have done similar repairs using aluminum foil from the kitchen.
Rick
AB5ON
Forest Gumping through life
PostPosted: Sep Tue 08, 2015 2:26 am
In addition to cleaning and copper tape, I've used conductive graphite paint available to me in my lab.
I've never been really happy with any of these fixes.
PostPosted: Sep Tue 08, 2015 6:01 pm
I've been using this for years, always worked great for me!
http://www.mcmelectronics.com/product/C ... gle.com%2F
PostPosted: Sep Wed 09, 2015 1:06 am
thanks jim,
I knew there had to be a better way. Gonna grab some of that stuff...
PostPosted: Sep Wed 09, 2015 5:35 am
If its anything like the stuff we used in the TV shop I worked in, once its opened it goes bad real fast.
FrankB
WB7ELC
"The average family has 2.5 children. Where is the other .5 child?"
PostPosted: Sep Sun 13, 2015 10:00 pm
I have just cleaned the contact areas with alcohol and Q tips in the past for some flaky pushbuttons on remotes, with some success.
PostPosted: Nov Sun 01, 2015 4:53 pm
I purchased Circuit Works Rubber Keypad Repair Kit from Alliedelec.com for $22.28, allielec# 70219366.
It comes as 2 parts Adhesive .1 oz, and Curing Agent .01 oz, ( a little over 3 grams).
The instructions say it will repair over 50 rubber button contacts. The entire contents must be mixed in one setting.
I guess you need to have several devices to repair at once or it gets expensive.
At 22.228 plus shipping & handling, I'm still waiting to use it for the first time, so I can't say how well it works yet.
PostPosted: Nov Sun 01, 2015 11:08 pm
My car key fob-remote stopped working a few yrs ago; dealers wanted hundreds $$ to replace and reprogram all the fobs, but mine was the only one worn out; so I CA glued small circles of aluminum foil to the keys and it worked well for a few months, until we traveled to WashDC for our son's USNavyBand concert, held just outside US Capitol. We were 3 blocks from the van when a foil had came loose from the fob in my pocket & shorted to the Panic, setting the car off. By the time I ran back to the car, DC Police and FBI were there wondering why it had gone off. When I showed them the reason, they didn't appreciate my cheapness. I then repaired it with an $8 repair pad from www.keylessfix.com that has been fine for 5 yrs. I don't think they have pads for remotes other than cars. The Caikote (above) looks like "graphite paint" (Dixon, Acheson-Dag 154, used as conductive mount for SEM & dry-lube in player piano motors), but I had tried the Dag in my remote; it wore off too quickly; apparently the Caikote is better & lasts longer.
PostPosted: Nov Mon 02, 2015 1:50 am
Fred Scoles wrote:
...I then repaired it with an $8 repair pad from http://www.keylessfix.com that has been fine for 5 yrs. I don't think they have pads for remotes other than cars. ...
Thanks for the reminder. My second Chrysler key fob still works but lost a button and I've been thinking of doing something about that for ages. Didn't find one there but found a replacement case/keypad on Amazon for $5.95, free shipping, and ordered it.
PostPosted: Nov Mon 02, 2015 9:02 pm
When I had bought the GM pad from keylessfix, all they had were for GM's because a few years ago, it was known that the crappiest, poorest built, shortest lived, junkiest, key fob's came with GM's.. Anything else had a higher quality fob. Is that still the case?? At $8 per pad, I'm considering getting a couple more from them, for when my wife's & my fob's go bad next time. Also, I learned to not drop fob on a hard floor because it can knock loose the battery prong solder connections from board; easily repairable, though.
PostPosted: Nov Tue 03, 2015 12:25 am
If you're asking me I couldn't say since I never paid any attention to 'key fob quality'. I mean, you're pretty much stuck with whatever it is so why bother?
Having said that, I've been generally satisfied with my Sebring fob, save the one missing button.
In anticipation of the new housing I dismantled the current one. It comes apart with a discretely hidden 'dime slot' you use to twist the halves apart.
The 'sealing' is done by the same rubber shroud the buttons are molded into and you can see what happened to my large 'unlock' button. For some reason the rubbery layer failed and it just fell out somewhere. There's no electrical connection.
The 'snap action' buttons are on the separate Mylar layer, electronics board underneath. This is why it still works.
The outer casing is like 'hard rubber', stiff but not plastic feeling, resin type PA+PPE. The batteries (2 x CR2016) make spring contact with the PCB. As a side note, I've never had to replace the batteries in either FOB.
PostPosted: Nov Tue 03, 2015 2:01 am
One problem I have seen with the GM FOB is that the solder on the Battery Holder
gets fractured. Just taking it apart and re-soldering them has fixed several for me.
One of mine that I have fixed looks like this one.
http://www.audiovideo2go.com/chevy-impa ... 12-2013-1/
In GM's defense, I have had to do the same for the Dodge Ram Pickup as well.
