It is currently Apr Thu 02, 2020 11:34 pm
 Post subject: Clean Rite Purple Power and Brakleen/Lectra-Motive cleaner
PostPosted: Aug Fri 04, 2017 10:32 pm
While cleaning my Sencore TC-130 I did exactly what this guy says not to do.
After pulling the meter, I sprayed the guts with Clean Rite Purple Power, rinsed it under a hot water faucet, and blew out it out with compressed air. It looked great and then I read this blog:
http://tubesound.com/2008/08/12/repair-calibration-sencore-mighty-mite/
According to this guy, the purple power stuff leaves a microscopic conductive film that ruins the leakage test function of this tester.
After that screw-up I went to my local farm store and got a can of CRC Brakleen (red) and CRC Lectra-Motive spray. Both cans contain tetrachloroethylene 127-18-4 and carbon dioxide 124-38-9, both smell the same, and both have the same nozzle and straw. The only difference seems to be that Lectra-Motive is harder to find, costs more money, and has different graphics on the label. They do eat plastic so you have to be careful what you spray, but the tester survived and the leakage function works as it should.
Matt
 Post subject: Re: Clean Rite Purple Power and Brakleen/Lectra-Motive clean
PostPosted: Aug Sat 05, 2017 4:16 am
Purple Power is great stuff - for cleaning my car engine. I never thought of using it on electronics.
I'd rather be on the ground wishing I was in the air,
than in the air wishing I was on the ground.
PostPosted: Aug Sat 05, 2017 6:31 am
I use purple power to clean tuning caps then rinse thoroughly and have never had a problem,although it may cloud shiny aluminum.
If they can't find you handsome at least they can find you handy !! Red Green.
PostPosted: Aug Sat 05, 2017 11:39 am
I use CRC Electronic Cleaner, available at auto parts stores everywhere, not expensive, and since it's specifically for electronics, there's no need to go to brake cleaners, etc. Won't harm most plastics, it says.
Reece
PostPosted: Aug Sat 05, 2017 12:39 pm
I recently used CRC Spray MAF (Mass Air Flow sensor) cleaner on our Crosley's volume pot. It is also "plastic safe" and dries without leaving any residue. Only reason I used this rather than the electronic cleaner is that I had it on hand. Wouldn't surprise me if it is the same stuff in a different can.
Do what you can, with what you have, where you are. - T.R.
PostPosted: Aug Sun 06, 2017 2:14 am
The purple cleaners are highly caustic... NEVER use them on Bakelite or other phenol resin thermoplastics.
When I use them as degreasers and soil removers, I always follow with a zap in the ultrasonic with sodium bisulfite (dry acid) to neutralize and then a rinse in plain water.... You wind up with a residue free part.
Robert
Post New Topic Post Reply  [ 6 posts ]  Moderator: Chuck Schwark
