It is currently Jul Sun 05, 2020 11:42 am
 Post subject: Really neat reproduction dogbone resistors!
PostPosted: Jun Thu 11, 2015 5:15 pm
http://www.ebay.com/itm/Dogbone-Resisto ... 43dd657861
I am sure this is very time consuming. The price seems quite reasonable considering the time and effort!
http://pages.suddenlink.net/davesradios/
 Post subject: Re: Really neat reproduction dogbone resistors!
PostPosted: Jun Thu 11, 2015 5:20 pm
44 billion ohms?
That must have taken some effort.
PostPosted: Jun Thu 11, 2015 5:53 pm
I agree with Dave. That's very nice work at a very reasonable price considering how much time it must have taken to make those. :shock:
Bob
"The stupider it looks, the more important it probably is!" -- J.R. "Bob" Dobbs
PostPosted: Jun Thu 11, 2015 11:18 pm
Wow, I think that is great.
PostPosted: Jun Fri 12, 2015 2:11 pm
The seller is to be commended for doing an excellent job and proving a good product for a very reasonable price.
It might also be to his advantage to brush aside his bonehead bidder with the question, since he is expecting an engineering report.
PostPosted: Sep Mon 09, 2019 2:31 am
I have 1938 Richenbacher steel guitar amp I’m restoring and want to replace the way-out of spec resistors. Haven’t found a schematic but doing a direct replacement of each component with re-stuffed caps. Want to do the same with the resistors -I’ve attached a pic of the majority of the resistor circuit, The Orange bodies are no-brainers a 300K and a 35K, the Black a 50. But with the other 3 I’m not sure if I'm looking at red bodies or brown bodies. The color favors more of a maroon. So these could either be Brown Green Yellow -150K or Red Green Yellow -250K. the two that are tied together are from the 2 guitar inputs. Any thoughts? Also anyone know a source for reproductions?
Micajah
"Ten percent of nothin' is-let me do the math here, nothin' into nothin'... " Jayne
PostPosted: Sep Mon 09, 2019 12:03 pm
Those 3 resistors look like 250K to me
There is a 100K laying against the 0.05 MFD cap
Then a 15K at the bottom of the image.
That is what i see. The orange dot on the lower one helps indicate the body color is brown.
If both body and dot were orange, then you would not see any dot at all.
PostPosted: Sep Tue 10, 2019 12:58 am
Are the resistors way out of tolerance?
PostPosted: Sep Tue 10, 2019 3:02 am
The Red Green Yellows (supposed to be (250K) measure from 297, 320, 314 and 391,
The Brown Black Yellows (100K) read 156K and 127K 0 though they still look orange to me, but Brown makes sense - with them being closer to 100K
The Brown Green Orange (15K) measures 22K
Micajah
PostPosted: Sep Tue 10, 2019 3:07 am
So the Black Green Brown in the far upper right would be 50 ohms?
PostPosted: Sep Tue 10, 2019 3:08 am
Steve Olson - a member here makes his own:
https://www.youtube.com/watch?v=0ddMuSt_aR4&t=78s
PostPosted: Sep Tue 10, 2019 11:43 am
Oh I missed that one... which is very odd. I've not seen a resistor start with black.
What does it measure?
I wonder if it got mis marked and is supposed to be 500 ohm?
P.S. If you could obtain hollow tubing with those ribs of the right diameter, slide modern resistors inside then wrap leads onto them it would simulate the originals.
PostPosted: Sep Mon 16, 2019 3:29 pm
Steve - you inspired me - so I made my own repros - the Black Green Brown after closer inspection - and brighter light ended up to be Violet Green Brown - 750 ohms. So here's the before and after. Also going to put a note into the amp for any future restorers that the caps have all been re-stuffed and that the resistors are all modern equivalents and the date of the restoration.
PostPosted: Sep Mon 16, 2019 3:44 pm
Wow, really good job. Your reds are really good, but the new resistors oranges look like brown on my monitor. Is the resistor laying across the .05 cap supposed to be yellow-black-orange (40K)? Looks like yellow-black brown. Maybe it just the camera ? .
EDIT: Reread the postings and see you have measured the original closer to 100K, so the body colors you have are correct. Wait, I need to reread and think this thru ??
Yeah, your markings are better than the faded originals. :D
PostPosted: Sep Mon 16, 2019 4:41 pm
Now those are impressive! :D
Great work! Yes, I can believe the purple faded so dark it looked black. Good save!
I assume you used hot melt glue in the caps? For a more natural look you could use the glue up to within a 1/4 inch of the end, then cap them off with natural (yellow) beeswax. I get blocks of the stuff at Hobby Lobby. as seen here.
https://www.hobbylobby.com/Crafts-Hobbi ... ck/p/24978
Post New Topic Post Reply  [ 15 posts ]  Moderator: Lou deGonzague
