It is currently Jul Tue 14, 2020 11:22 am
 Post subject: Tech Question from Ebay transformer
PostPosted: Mar Sat 16, 2019 3:05 pm
"Windings can be combined to create a multitude of voltages.(.636 volts AC= 1 volt DC combining the 2 26 volt windings will give you 90 volts DC)"
Is this right? (26+26)=52/.636 => 81.8 (??) With a bridge, capacitors and/or a choke?
https://www.ebay.com/itm/Transformer-for-building-battery-eliminator-for-your-vintage-antique-radio/223449378175?hash=item34069eed7f:g:d2sAAOSw~gZcXx8-
 Post subject: Re: Tech Question from Ebay transformer
PostPosted: Mar Sat 16, 2019 5:39 pm
Makes no sense. 52 volts RMS is ~73 peak. That is the DC voltage that you get with 100% rectification efficiency. Even if the efficiency is 90%, that's a bit over 63 volts. The 0.636 factor looks like the average value of a sine wave, which is irrelevant.
-Mark
PostPosted: Mar Sat 16, 2019 6:23 pm
Generally voltage is figured as 52v x 1.414= 73.52v, factoring transformer impedance, usually a little less with load.
PostPosted: Mar Sat 16, 2019 8:21 pm
Actually, the typical transformer is speced with a stated load current, so the max with no load is even higher......but that transformer is not going to produce 90 VDC, regardless
-Mark
PostPosted: Mar Sat 16, 2019 9:51 pm
I was thinking along the same lines, just wanted a reality check. Except I'm thinking it's 52V peak/peak => 38VDC max! :?
PostPosted: Mar Sat 16, 2019 11:16 pm
??--a transformer voltage---or any AC voltage---is normally stated as rms. 2 windings, 26volts rms each = 52 volts rms
If it were 52 P-P, thats 26 peak, and the DC voltage approaches that with no load
-Mark
Post New Topic Post Reply  [ 6 posts ]  Moderator: Lou deGonzague
