Page 1 of 1
[ 14 posts ] |
Author |
radioterry
Post subject: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Wed 13, 2019 4:33 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4226 Location: Eschew Obfuscation Virginia 23005
Top |
Ray P
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 2:38 am |
Joined: Jun Thu 05, 2008 6:28 pm Posts: 733 Location: Santa Rosa Ca
What do you think about it? Ray
Top |
atwaterkent1
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 3:16 am |
Member |
Joined: Sep Mon 18, 2017 2:23 am Posts: 6367 Location: Plymouth, MI
It's not bad. Board has been refinished and cap replaced. Sold As-Is. I would like to see a photo of the T/A insides. I wouldn't buy it, but many will be interested.
_________________ Dan
Museum Curator https://roaringtwentiesantiqueradiomuseum.com/
Top |
radioterry
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 3:40 am |
Member |
Ray P wrote: What do you think about it? Ray There are two well known Atwater Kent experts here (atwaterkentsrus and leigh) maybe they will respond to your question. GL, Terry
Top |
atwaterkent1
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 4:42 am |
Member |
Ray - It's the early version of the model 9, 4445. The later 9C, 4660 used condensers instead or variometers. There's also a 9A, 4445A with a different layout also using variometers. I have the 9 and 9A. If you don't have one and the price is right, why not? I would ask for pics of inside the tube island.
( I just ordered a case for the AK12. Did you get the Radiodyne we had talked about awhile back Ray?)
Top |
Indiana Radios
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 2:09 pm |
Member |
Joined: Sep Thu 14, 2006 3:27 pm Posts: 13446 Location: Carmel, Indiana
I wouldn't pay as much for this example as I would for one in all original nice condition but I'm sure someone will.
What is this model normally valued at in nice original condition?
_________________ Michael Feldt
www.indianaradios.com
Top |
Ray P
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 3:20 pm |
Top |
atwaterkent1
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 4:21 pm |
Member |
Indiana Radios wrote: I wouldn't pay as much for this example as I would for one in all original nice condition but I'm sure someone will.
What is this model normally valued at in nice original condition? I would't be surprised to see one that's all original go for $1600.00 or more in very good condition, especially the earlier versions.
Top |
atwaterkentsrus
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 5:16 pm |
Member |
Joined: Apr Wed 23, 2008 2:34 am Posts: 1098 Location: Silsbee, Tx
It's obvious it's not 100% original, but not in bad condition. If the TA unit is still untouched inside, I would think it would be worth about $900 -$1000. I wouldn't be surprised to see a $1200 bid. It does have one of the paper tags on the bottom, which is a good thing.
_________________ Thanks, Jimmy
http://www.atwaterkentsrus.com
Top |
atwaterkent1
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Fri 15, 2019 11:12 pm |
Member |
Top |
radioterry
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Tue 19, 2019 1:49 pm |
Member |
atwaterkentsrus wrote: It's obvious it's not 100% original, but not in bad condition. If the TA unit is still untouched inside, I would think it would be worth about $900 -$1000. I wouldn't be surprised to see a $1200 bid. It does have one of the paper tags on the bottom, which is a good thing. Jimmy: I think you nailed it, with 12 hours to go it is @ $1,286.00BR, Terry
Top |
radioterry
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Wed 20, 2019 1:31 am |
Member |
Top |
atwaterkent1
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Wed 20, 2019 1:32 am |
Member |
Top |
xeric
Post subject: Re: Atwater Kent 4445 (Model 9) Breadboard Posted: Mar Sat 23, 2019 7:31 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 683 Location: Henderson, NV
Opening a TA, if original, could possibly break the brittle sleeves of the wiring coming from the tar. Probably won’t create any problems. ________________ xeric N7CAH
Top |
