It is currently Feb Tue 18, 2020 12:15 pm
 Post subject: Patterson 105AW console
PostPosted: May Tue 07, 2019 8:11 pm
Cheap, too at $15. Wonder how bad the veneer is?
https://fortcollins.craigslist.org/atq/ ... 84123.html
Me transmitte sursum, Caledoni! Dan B
 Post subject: Re: Patterson 105AW console
PostPosted: May Wed 08, 2019 3:13 pm
Very nice!
Wish I could save them all.
Rodney -- KG7EPW
PostPosted: May Wed 08, 2019 4:03 pm
Craig aka analogtv wants it- hope he gets it.
PostPosted: May Wed 08, 2019 5:47 pm
The models with that dial have a nice band indicator that turns the band name through a window when you rotate the band switch.
Good luck, Craig!
Rodney -- KG7EPW
PostPosted: May Wed 08, 2019 6:07 pm
That's a giveaway for a great little console. The veneer work shouldn't be too tough if it's just on one side. I would do just a partial resto to the cabinet.
PostPosted: May Wed 08, 2019 8:42 pm
I have the boatanchor version of that model, and it is a really good receiver. If it wasn't halfway across the country....
PostPosted: May Sat 11, 2019 1:52 am
So there is a 12 tube Patterson PR-12 Chassis in there?
BR,
Terry
PostPosted: May Sat 11, 2019 2:16 am
BR,
Terry
10 tubes.
PostPosted: May Sun 19, 2019 9:53 pm
It is a Patterson 105-AW, with ten tubes, output push/pull 42's feeding a dried out Jensen type D pedestal speaker. Somebody cut steel pipe to size and slid over several tubes. Somebody,....somewhere,....found out shields were needed, as the old ones were gone.....and had a good idea. It now has the shaped aluminum ones. Somebody has partially re-capped long ago, not surprising. The veneer was replaced with mahogany on the two sides and top and it was badly done. I don't even mind the poly, heck, l've used it myself. This is the first Patterson I've run acoss, should be interesting. Craig
PostPosted: May Sun 19, 2019 11:44 pm
How about a few pictures?
Post New Topic Post Reply  [ 10 posts ]  Moderator: Lou deGonzague
