It is currently Oct Wed 20, 2021 9:43 pm
 Post subject: Quiz of the day…
PostPosted: Sep Thu 16, 2021 11:30 pm
Why hasn’t this radio been tested to see if it works?
https://www.ebay.com/itm/114994478481
 Post subject: Re: Quiz of the day…
PostPosted: Sep Thu 16, 2021 11:54 pm
Because it didn't come with a remote, the seller can't find a button to turn it on.
:wink: :wink:
PostPosted: Sep Fri 17, 2021 12:29 am
Because the ultra rare 9V battery is missing from the box. You can clearly see the empty cut out in the pictures.
PostPosted: Sep Fri 17, 2021 1:38 am
Couldn't find the receptacle to plug in the Apple power adaptor cord.
Michael Feldt
www.indianaradios.com
PostPosted: Sep Fri 17, 2021 2:22 am
She would have to spend a couple of bucks just to be disappointed.
PostPosted: Sep Fri 17, 2021 2:52 am
Maybe it was tested and failed and then suddenly became untested. :wink:
Dan
Museum Curator
PostPosted: Sep Fri 17, 2021 3:01 am
It would work much better if the black wire going to the battery snap connector wasn't broken. (which means it was actually tested but didn't work)
PostPosted: Sep Fri 17, 2021 5:14 am
Wear on the bezel, so hardly good condition, just because it has the box.
Another case of a used common radio with decimalpointitis, which needs to be moved leftward one digit.
PostPosted: Sep Fri 17, 2021 2:43 pm
Why do you need to know if it works?
An eight year old kid could fix that little set if required… maybe you don't how to. lol
anyhow… a blind man could see that the circuit board and all of the component are original and unmolested.
If it's really buggin' you that much, why don't you ask the seller.
https://i.ebayimg.com/images/g/ieMAAOSw ... -l1600.jpg
PostPosted: Sep Fri 17, 2021 3:11 pm
atwaterkent1
Buyers have brought this on themselves, screaming "It don't work" and demanding a refund. The path of least resistance now is to start with, "Maybe it will, maybe it won't". :D
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Sep Fri 17, 2021 5:25 pm
The small electrolytics are bad after 50 or 60 years
but heh there is a schematic
PostPosted: Sep Fri 17, 2021 8:36 pm
That's usually the case with these '60's Japanese made sets (or really most any other manufacturer).
WE don't really need a print in order to change out the usual four E-Caps, nor would it do any good for a non-electronics person.
PostPosted: Sep Sat 18, 2021 9:58 am
It's hard to think outside of the <unopened> box?
Post New Topic Post Reply  [ 13 posts ]  Moderator: Lou deGonzague
