It is currently Oct Sat 23, 2021 7:45 pm
Post New Topic Post Reply  [ 1047 posts ]  Go to page Previous  1 ... 49, 50, 51, 52, 53
 Post subject: Re: LM386N MK-XI BCB Transmitter
PostPosted: Jul Tue 06, 2021 7:42 am
That's an unusual way to draw the LM386.
The usual output position on the triangle is the Vcc?
What did you have for the antenna length?
PostPosted: Jul Tue 06, 2021 7:48 am
Here it is on the breadboard
Dan
PostPosted: Jul Tue 06, 2021 7:52 am
Used the "PCB Express Plus" software they didn't have a LM386 in the database oddly enough, so I modified an existing DIP-8 part.
Ant length is about 5.5 Ft
Edit, I have a 33pF in line with my variable, so that' with about 40 pF on it.
Dan
PostPosted: Jul Tue 06, 2021 8:30 am
You mean 33pf in parallel with the variable, right? In line sounds like series, which would reduce the capacity, of course.
Looks like a major change in RF filtering between the LM386 & the OSC, more inductance & bypass caps, too.
I assume L2 & C9 may need tweaking if other than 1000Khz OSC is used instead.
PostPosted: Jul Tue 06, 2021 8:32 am
Here is something from my last one:
Dan
PostPosted: Jul Tue 06, 2021 8:38 am
Correct on the cap. Not sure on the Osc. I have a 1.2288 but never use it due to the earlier mentioned oscillation. Have tried literally every value of every part, within reason and sometimes not, in that config including versions of the 386 (8 ohm and 32 ohm "4" version) but not the OSC.
Dan
PostPosted: Jul Tue 06, 2021 8:43 am
Notes from my first build that could do both:
"Running it on 6 AA batteries (9v). The LED is running on the 9V. Has a 220uh and 330uh L2 and works with a huge range of antenna sizes. I could have used just a 270uh with the 5-100pf tuning cap but antenna length was limited to about 6ft max at 1228 MHz and 2ft minimum at 1000 MHz while still being able to peak the antenna. A 40in antenna was perfect for a 270uh L2 peaking at about 33% and 66% of the capacitance range for 1228 MHz and 1000 MHz."
Dan
