It is currently Mar Tue 09, 2021 1:44 am
Post New Topic Post Reply  [ 1025 posts ]  Go to page Previous  1 ... 39, 40, 41, 42, 43, 44, 45 ... 52  Next
 Post subject: Re: LM386N MK-XI BCB Transmitter
PostPosted: Feb Mon 01, 2016 3:03 am
Wow, this thing works great! Just on the breadboard and have to cut the gain real low to keep from overmodulating. My current radio on the bench is a 41 silvertone with pushbuttons and I set one to pickup the transmitter without fiddiling with the dial. And with the radio right across the room its easy to peak by ear. A big thanks to everyone who worked on this kit!
I never loose. I either win or I learn.
PostPosted: Feb Mon 01, 2016 3:21 am
Drmitch, which kit are you referring to?
PostPosted: Feb Mon 01, 2016 4:11 am
I'd assume the heading gives that answer...
Dr if you have the resistor and cap connected from pin one to eight, those can removed to reduce audio gain...
PostPosted: Feb Mon 01, 2016 5:18 am
Thank`s Tom I`ll try that.
PostPosted: Feb Fri 12, 2016 8:34 pm
I planned to experiment with a batch of 1.544 SMD crystals I purchased, BUT I can't figure out which of the terminals to connect to get the correct configuration to replace my 1.228 crystal set-up. I see that positions 1 ( beveled term.) and 3 are in and out; and 2 is volts in?? with 4 as ground??. Also, I don't know the best way to mount these small units. Any help out there with SMD experience.
Thanks, Dale
PostPosted: Feb Thu 25, 2016 7:19 am
Thanks, Dale
Late to the thread, I know, but...
I'd be a little surprised if your guess at the pinout is correct. All the SMD osc cans I've ever seen are the same as most through-hole can oscillators i.e.
Where Pin 1 is marked by a dot or chamfer, and :
Pin 1 - Standby (high or o/c = enable, low/gnd = disable)
Pin 2 - Gnd
Pin 3 - Output
Pin 4 - Vdd (+ve)
DIP-packaged oscillators are usually the same pin layout too - just that the pin numbering follows DIP package conventions.
What make/model or supplier/part# are the ones you're using?
For prototyping/breadboarding or a through-hole board, I'd simply solder short lengths of solid hookup wire to the pads - it's not going to be a problem at broadcast band frequencies. Depending on the size, you could probably mount one on a SOIC-8 or SSOP-8 to DIP adapter board if you wanted something more permanent.
PostPosted: Feb Thu 25, 2016 3:50 pm
Thanks, Rod...exactly what I needed. Now, I'm off and running. Much obliged. I don't have a part number, just some Chinese SMD I wanted to try to replace the standard 1.228 and 1.000 KC plug-in oscillators.
Dale
PostPosted: Mar Wed 16, 2016 9:46 pm
Reading a little of this thread, it sounded like there were plans to produce this as a commercial kit. Is that still the case, or did I misunderstand?
The only difference between screwing around and science is writing it down.
PostPosted: Mar Wed 16, 2016 11:57 pm
Bill Hamre has a kit of most of the parts but AFAIK he's still wintering out in the Atlantic...
There was a member that produced a board and case and was selling a completed unit, of course he was run off cause we can't be selling built transmitters here on ARF... They were for sale on ebay, dunno if they still are...
PostPosted: Mar Thu 17, 2016 1:12 pm
Now had the member left the TCXO out and provided a socket for it, would it then have been legal since it is technically not a completed product?
Didn't another member here make a board for the LM-386 or was that a tube transmitter I was thinking about?
PostPosted: Apr Thu 07, 2016 8:52 am
Looking at Mouser for some LM386N - obsolete, not in stock.
They have some Ms, MXs, MMXs.
Do those work here? Thanks.
TDane WA9YI
Radio is a divine gift; God made us able to do one thing while listening to another.
PostPosted: Apr Thu 07, 2016 3:59 pm
AFAIK any LM386 will work, as updates/changes are made the suffix changes...
If you want L there are 1000s on ebay...
PostPosted: Apr Thu 07, 2016 8:53 pm
I think I bought 10 of them on The Bay last year for a buck. Looking there now, cheapest is 87 cents for 10, with free shipping. PRC seller, naturally.
PostPosted: Apr Thu 07, 2016 9:30 pm
I bought 10 also. http://www.ebay.com/itm/151820386186?_t ... EBIDX%3AIT
PostPosted: May Mon 16, 2016 7:04 pm
I'm thinking of adding the 1,228 osc and correct choke as a two part kit for any one stuck with the 1,000 in a bad frequency city. PM me if interested.
"All glory is fleeting" - George Patton
KB3QNN 73
PostPosted: May Tue 17, 2016 2:28 pm
Only one taker so far. I'm making a list as I'll be ordering in just these parts in the end.
EDIT: You might want to get these two parts in a #10 envelope and throw them on the bedroom closet shelf just in case you ever need 1,228 in the future. OR, someone your mentoring on here might need them someday.
KB3QNN 73
PostPosted: May Tue 17, 2016 5:02 pm
If possible try to get crystal oscillators which end in "0". A 1,228 oscillator will work for our older radios but new digital radios tune in 10 increments. Not sure what would happen with a station on "8"? Probably some distortion.
PostPosted: May Tue 17, 2016 5:22 pm
Ok, thanks for the heads up Norm.
KB3QNN 73
PostPosted: May Tue 17, 2016 8:21 pm
I built an AM transmitter from a kit sold by a Japanese seller on eBay, using a 1308 Kc fixed output frequency. It works just fine on digital radios, perhaps because of the close proximity (within 150 feet or so).
http://www.ebay.com/itm/1308kHz-Amplitu ... Swv0tVOdAQ
PostPosted: May Fri 20, 2016 2:21 pm
Anybody tried the 1,228 osc in the 386 broadcaster using digital radio on say 1,230? Just curious about findings.
KB3QNN 73
Users browsing this forum: j8000 and 11 guests
