It is currently Feb Tue 25, 2020 10:21 am
Post New Topic Post Reply  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: AM LOOP Antenna
PostPosted: Jan Sat 25, 2014 10:43 pm
davep wrote:
Fifties, log em over on lispo id like to see your stations 8)
You might try dropping various small caps between the diode and the amp to ground .
Lispo? Link please. Several of the stations at the upper end of the band are foreign language, and not just Spanish, so dunno if I'd be able to ID them.
Re dropping small caps, you mean like .1/.01 discs? Between Diode Cathode and ground? What effect would they have?
PostPosted: Jan Sat 25, 2014 11:10 pm
Hey fifties, you may now be bitten by the crystal radio DX bug! Sounds like your setup is working great. That's a hard one to shake.
Info, like Dave says, yes indeed. With a bit of playing around you might get some unexpected results. Once while using my loop with a transistor radio I hit a magic combination where the physical arrangement became uni-directional over at least part of the band. Cancellation, I guess.
-Bill
Visit my homebrew page
www.sparkbench.com/homebrew/homebrew.html
PostPosted: Jan Sun 26, 2014 12:29 am
Here 50s viewtopic.php?f=2&t=207609&start=640
PostPosted: Jan Thu 23, 2020 7:20 am
This looks likes good topic to be reviewed again. That loop antenna seems like it can be made with not a lot of work You seem to make it look easy. Any tunable cap will work ??? Tom
PostPosted: Jan Thu 23, 2020 7:29 am
Hey Tom,
I used one from a junked AA5. Using my bridge, it measured 405 pF, but I would imagine any metal air variable from an AM radio should work just fine. All you need to use on it is one of the gangs, whichever works better.
PostPosted: Jan Fri 24, 2020 6:47 am
I have a lot of the condensers in the junk pile. to try. I have several from some small radios I can give a try first. Thanks for the information. I need to get the hoops but that should not be a problem. Tom
