It is currently Jul Sat 11, 2020 12:13 pm
Post New Topic Post Reply  [ 45 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Power supply for farm radio
PostPosted: Jan Sun 29, 2017 11:29 pm
Re-read my last post. Given that batteries were made in specific voltage ranges, 45, 67.5, 90, 130, etc., radio manufacturers would recommend one of those standard voltages for their specific circuit.
If you look at the data for each tube, you can determine it's maximum plate voltage allowance. And again, varying by 10% shouldn't harm anything.
PostPosted: Jan Mon 30, 2017 12:08 am
Chas wrote:
When I was working I ordered for the shop a PACE triple re-work station. I can remember exactly the model number but it was in an attractive sculpted cabinet. That one bit of equipment literally made a technician hero out me. One of the best re-work soldering systems I have ever used. That and a China charcoal barbecue were my key equipment for repairing SM circuit boards. Barbecue? I'll tell what it did later, If you really want to know... Oh, the regret?
What did the barbecue do? Or was that just a variation of the toaster oven or electric skillet method?
PostPosted: Jan Mon 30, 2017 12:49 am
I see now. Yes, the voltage without the pot was only high by 6 volts. So I could probably do without it. Thanks.
Another option I have is to use a different tube. Norm Leal said "You could interchange an 0A3 and 0B3 in your power supply to change voltages. Same pin out, just different voltages", 75 volts in that case.
I imagine a Zener diode would drop the voltage too. I liked the pot because I could just dial in the exact voltage.
PostPosted: Sep Mon 16, 2019 10:52 pm
One more question. Why is it that everybody uses d batteries for the 1.5v? Won’t a 1.5v AA work?
PostPosted: Sep Mon 16, 2019 11:36 pm
Because a AA battery wouldn’t last long enough. One could be used, of course, but it would require replacement at very frequent intervals.
