Page 1 of 1
[ 15 posts ] |
Author |
FreeElectron
Post subject: Lots of speakers? Posted: Dec Tue 12, 2017 8:50 pm |
The lower notes, bass notes, usually are produced be large diameter speakers so what if you gathered together enough small speakers that equals the area of a big one, would that reproduce more bass? Fred
Top |
pixellany
Post subject: Re: Lots of speakers? Posted: Dec Tue 12, 2017 8:56 pm |
Member |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 29154 Location: Annapolis, MD
Yes, but_______________________
(I'll let the blanks to be filled in by more knowledgeable people....)
_________________ -Mark "Voltage is fun to watch, but it's the CURRENT that does the work."
Top |
Eickerman
Post subject: Re: Lots of speakers? Posted: Dec Tue 12, 2017 8:58 pm |
Member |
FreeElectron wrote: The lower notes, bass notes, usually are produced be large diameter speakers so what if you gathered together enough small speakers that equals the area of a big one, would that reproduce more bass? You probably want to do a little reading about the "Sweet Sixteen" speaker array. Here is one example... http://techtalk.parts-express.com/forum ... teen-arrayThe short answer is yes. The longer answer is that an array of speakers has some drawbacks exactly because it is an array (beaming, off axis distortion, etc.). It is the sound equivalent of a directional RF beam antenna. Wow I am getting old. I remember as a kid reading about the Sweet Sixteen in Popular Electronics. Apparently it was January 1961. There is a web site around someplace where you can read old PE issues online. Yep page 55, January 1961 found here... http://www.americanradiohistory.com/Pop ... -Guide.htmHere is the direct link to just that issue... http://www.americanradiohistory.com/Arc ... 961-01.pdfCurtis Eickerman
_________________ http://curtiseickerman.weebly.com
Top |
easyrider8
Post subject: Re: Lots of speakers? Posted: Dec Tue 12, 2017 9:27 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 10748 Location: Mpls, Minnesota
Top |
Eickerman
Post subject: Re: Lots of speakers? Posted: Dec Tue 12, 2017 10:08 pm |
Member |
easyrider8 wrote: I built that one, not really impressed with the performance. Yeah, that's the feeling I get from the postings I have read about it. There probably is more bass response if you are standing in just the right place. However, with 16 in-phase radiators, the 3 dimensional interference pattern probably made it sound pretty strange if you moved. Not to mention using two if them on a stereo system. Curtis Eickerman
Top |
glue_ru
Post subject: Re: Lots of speakers? Posted: Dec Wed 13, 2017 1:17 am |
Member |
Joined: Dec Tue 01, 2015 5:31 am Posts: 2893 Location: Columbus Ohio
look at the Bose 901, the real key with those is the equalizer.
_________________ Joe - There's no shortage of cruelty to animals: http://joinASPCA.org
Top |
Elvirafan
Post subject: Re: Lots of speakers? Posted: Dec Wed 13, 2017 5:24 am |
Member |
Joined: Feb Sun 05, 2012 5:12 pm Posts: 1047 Location: North Syracuse NY 13212
As one reader commented (I remember that article very well), "Sixteen times cheap is still cheap".
Bob
_________________ Life is too short to be serious all the time.
Top |
SteveT
Post subject: Re: Lots of speakers? Posted: Dec Wed 13, 2017 8:34 pm |
Joined: Mar Tue 03, 2009 11:12 pm Posts: 1776 Location: Great Bend KS
I think I remember reading that in multiple speaker systems the distortions figure of each speaker are added, if one speaker has 1% distortion, 16 would have 16% distortion. Or am I hallucinating in my old age?
Top |
Mike Toon
Post subject: Re: Lots of speakers? Posted: Dec Wed 13, 2017 8:47 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6024 Location: Beautiful Downtown Burbank CA
A friend, Cliff Bean, built the sweet sixteen and in a small room completely covered with cardboard egg cartons for sound deadening didn't sound too bad. (Not as good as I expecting for all the work he did though) After few beers, In-A-Gadda-Da-Vida sounded pretty good. Cliff gave up on the speakers and went on to make guitars. Aluminum neck guitars. He used his middle name, Travis. Travis Bean Guitars. RIP Cliff.
Top |
westcoastjohn
Post subject: Re: Lots of speakers? Posted: Dec Fri 15, 2017 1:50 am |
Member |
Joined: Dec Sat 24, 2011 9:17 pm Posts: 7161 Location: Vancouver Island, Canada
Mike Toon wrote: A friend, Cliff Bean, built the sweet sixteen and in a small room completely covered with cardboard egg cartons for sound deadening didn't sound too bad. (Not as good as I expecting for all the work he did though) After few beers, In-A-Gadda-Da-Vida sounded pretty good. Cliff gave up on the speakers and went on to make guitars. Aluminum neck guitars. He used his middle name, Travis. Travis Bean Guitars. RIP Cliff. I remember those from the 70's. Wild idea that worked, I think, but I've never seen one. I think I remember In-a gadda-da-vida-baby, but maybe I just think I do.  Actually that song started out as In a Garden of Eden, bit of trivia there.
_________________ Watch the doughnut, not the hole. Burl Ives, RIP, oldtimer. [:l>)
Top |
Ed in SoDak
Post subject: Re: Lots of speakers? Posted: Dec Mon 18, 2017 9:22 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5450 Location: Black Hills, SD 57745
That Popular Electronics' Sweet Sixteen concept kept coming back over the years. By March of '67 it had morphed to a dozen drivers of mixed sizes, then even that system was debunked in the November 1970 issue. By that time, the final word was the presumed cost savings had vanished due to better woofers and higher cost of the large wood cabinet. Attachment:
If you have a big stash of speakers to play with and scrap plywood to match, why not build one? But the thought of cutting all those holes, the wiring and where to put the big, mediocre-sounding result, it's interesting to read about but not too enticing to build. Especially when for about the same cost you can pick up some modern drivers, stuff 'em in a spare empty "white van" enclosure and have much nicer sound. Attachment:
One source of drivers: https://www.allelectronics.com/category ... ers/1.html I bought the 10" and 8" a few years back and they are both excellent lost-cost woofers. Coupled with a 4" midrange and dome tweeter either made a nice-sounding speaker. -Ed
_________________ My life is loosely based on a true story.
Top |
radiotechnician
Post subject: Re: Lots of speakers? Posted: Dec Mon 18, 2017 3:37 pm |
Joined: Sep Thu 23, 2010 6:37 am Posts: 12437 Location: Powell River BC Canada
From the point of view of someone experimenting with a large number of different speakers, the object might be having a very large sound radiating surface.
As long as the speaker voice coils can carry an amperage inversely proportional to their impedance (~DC resistance) between 4 and 16 ohms, they could be combined into a 16 or 8 ohm bin.
Makes a squawker, fairly sensitive. If you nail a back onto the cabinet, bass will result.
Could entertain a crowd at a Hammond organ recital.
Years ago, a division that was run by Dave, contracted out sound. His idea of keeping the night alive, and loud, was to have a fake speaker do Pyrotechnics at a chosen moment.
Top |
Sol
Post subject: Re: Lots of speakers? Posted: Dec Mon 18, 2017 7:08 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1381 Location: Bend OR 97703
Top |
radiotechnician
Post subject: Re: Lots of speakers? Posted: Dec Mon 18, 2017 8:31 pm |
I wonder if those long arrays were placed around a live hall.
How intelligible* would it sound?.
I went to a AES demo of the computerized system in Vancouver 20 years ago. It went well. Sticking a handy cam with tape to something didn't .It fell off.Very slick way to do room profile.
Old way. * the test is a series of words read from the stage, and scored by people in the seating area, to see how many are understood.
Top |
K9DXL
Post subject: Re: Lots of speakers? Posted: Jan Fri 05, 2018 5:25 am |
Anyone interested in speaker building should know about Parts Express. www.partsexpress.com No, I have no stake in the company, but can attest that their customer service is very good.
Top |
Page 1 of 1
[ 15 posts ] |
Users browsing this forum: No registered users and 13 guests |
