It is currently Jul Wed 24, 2019 12:05 am
Post New Topic Post Reply  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Components Swapouts
PostPosted: Aug Fri 24, 2018 2:27 pm
I am looking for anyone that can help me understand components.
I have built in my Ham lifetime dozens of kits. And serviced broken radios. But it has always amazed me about the components. Like Resistor 222, why is it 47 ohms and not any other value? Or Coil L 3 why is it 55 turns of 28 ga wire close spaced on a 2 inch form. what would you change if the only form you had was 2.5 inches? why not any other values or say same items that are best for 40 meters, what do you change for 30 meters? Anyone?
More or less, what my goal is to take some ultra basic old Tube designs of simple equipment, Some are super simple like two tubes and maybe a total of a dozen support components, but change it out from a Tube to a transistor. There has to be a transistor that can do the job that any tube did.
But the mystery to me is to learn What Transistor to replace tube "X" and then the support perferial components what needs to change to work with the new transistor?
Joe WB9SBD
 Post subject: Re: Components Swapouts
PostPosted: Aug Fri 24, 2018 3:39 pm
Wow. That's a big order.
You might start out with something like TM-11-455. This is a DC theory manual used by the Signal Corp in the '50's and go on from there.
Bruce Hagen
PostPosted: Aug Fri 24, 2018 3:49 pm
Hi Bruce,
Thanks for the reply, see I'm a Radio Amateur and have built many a transmitters. But never really understood the Why a component is what it is, And I was recently turned onto a sub activity where guys put on the air extremely old designs. Like the first generation after Spark Gap transmitters, Really simple designs like this,
Finished unit,
I want to try to make the exact same unit but with modern components.
Joe WB9SBD
PostPosted: Aug Fri 24, 2018 4:28 pm
It sounds like you need a crash course in the basics....
Where are you on the following?
--basic tube theory
--basic properties of resistors, capacitors, and inductors
--current and voltage relationships for both AC and DC
-Mark
PostPosted: Aug Fri 24, 2018 4:48 pm
--basic tube theory
I was under the (mis?) understanding that basic knowledge of electricity, electronics including resonance and EIR relationships was an essential part of the Ham testing and knowledge?
PostPosted: Aug Fri 24, 2018 5:00 pm
Your request isn't a simple one. To design/build a radio, you need to understand how it works and what you expect from it. No simple recipe for "swapping" components.
If you want to build a simple transistor receiver, for the AM band or shortwave, search for "transistor regenerative receiver."
Here is one site: http://www.techlib.com/electronics/regen.html
http://makearadio.com/solidstate/index.php
There are lots of simple ham receivers available from China on Ebay. May be a good place to start?
https://www.ebay.com/itm/DIY-Kits-Super ... SwBLlVWj2h
https://www.ebay.com/itm/Simple-3-band- ... SwIaFZLmP0
http://www.mfjenterprises.com/Product.p ... =MFJ-8100K
PostPosted: Aug Fri 24, 2018 8:00 pm
Joe WB9SBD
If I understand your definition of "modern," in your circuit the tube is the only component that's not modern. It can probably be replaced with an FET. Here's an article on doing just that:
https://www.google.com/url?sa=t&rct=j&q ... QrYX-1lHdj
As for how worthy a project, discussion here:
https://www.eham.net/articles/30168
http://forums.qrz.com/index.php?threads ... st.394077/
PostPosted: Aug Fri 24, 2018 10:35 pm
This circuit should work but often we are looking for stability. This one isn't going to be stable.
PostPosted: Aug Fri 24, 2018 10:42 pm
what circuit?
PostPosted: Aug Fri 24, 2018 10:48 pm
The one above using a 27 tube. You could use a more modern 6C4?
PostPosted: Aug Fri 24, 2018 10:58 pm
Hi Norm,
See thats the whole, project, to take a simple circuit like that above. but no tube use a transistor instead.
PostPosted: Aug Sat 25, 2018 12:02 am
Typically, you cannot just put in a transistor in place of a tube......transistor circuits are normally lower impedance than the equivalent tube circuit. You could use a FET, but some changes are still required,
For the oscillator circuit, solid state designs often use as Colpitts configuration, as opposed the the Hartley shown.
-Mark
PostPosted: Aug Sat 25, 2018 2:21 am
Apologies. I should have noticed that the original circuit is a transmitter, not a receiver.
As others have said:
--No plug-in swap of transistor for tube
--That circuit is primitive and not stable
Why not just build a crystal-controlled transistor transmitter?
PostPosted: Aug Sat 25, 2018 4:32 am
But yes not stable, but that's the whole thing. to USE technology that was at the roots of Amateur Radio,
http://www.antiquewireless.org/bruce-ke ... -info.html
PostPosted: Aug Sat 25, 2018 2:33 pm
You want to build 1929 designs, use the same kinds of parts.
Were you thinking of just plugging a transistor into one of those circuit? Do you understand why that won't work?
-Mark
PostPosted: Aug Sat 25, 2018 3:07 pm
Yes I fully understand why it would not work.
And thats why I thought about asking to see if anyone with better knowledge of designing might want to make something fun.
But In the few places I have asked about this, I honestly see the experimental aspect of Amateur Radio is dead and gone.
Trying things that are not common. Just for the fun of it.
Like some days I use one of these, to do CW with.
I have several that fall into the CW sub bands. They have a 5 volt peak ummm "WAVE"?
It is not a sine wave, or Square wave either. AND, they only go to one side of zero, unlike a sine wave
The power when measured with a watt meter is about 70 milliwatts. I have made hundreds of contacts using these things. And amaze people when I tell them what I am using.
A Straight key to turn the power to it on and off,
3 AA Batteries, 4.5 volts
and the little metal can!
That's it.
Actually a bunch of fun.
I just thought Id try again something Old but also new, with converting one of these 1929 units to modern components.
Sorry about not wanting to be only an appliance operator
Joe WB9SBD
PostPosted: Aug Sat 25, 2018 3:21 pm
No one is trying to discourage you from experimenting.
What will work:
Take a classic design, learn how it works, and then design the modern equivalent with modern parts.
What will NOT work:
Plugging modern parts into a classic circuit with no understanding of how the circuit works and/or no understanding of the modern parts.
Repeating an earlier question: What is your level of experience with basic theory and principles of circuit design? For example, do you understand why a junction transistor cannot be subbed for a vacuum tube?
-Mark
PostPosted: Aug Sat 25, 2018 3:38 pm
Obviously Voltages and impedance's are totally wrong.
But what solid state device could do the job a #27 tube does, Not a clue. If the solid state device had the correct support design around it.
PostPosted: Aug Sat 25, 2018 3:55 pm
The experimenting aspect of ham radio is very much alive. It is based on knowledge of basic electronic circuits. It is not just plugging parts together to see what happens. Get yourself an ARRL Handbook or one of the ARRL QRP books and start learning about basic circuits.
What modern engine could I put in a '29 Ford, if it had the right support design around it? Same kind of question. If you knew how to modify all the mechanical structures, pulleys, shafts, belts, etc. it could probably be done.
People have designed 'solid state' tubes using FETs. (The Fetron). They work in specific circuits to replace specific tubes. No one has ever made a universal type 27.
http://hrsasa.asn.au/docs/Fetron.pdf
PostPosted: Aug Sat 25, 2018 4:25 pm
I Guess I'll end this string now.
The spirit of experimenting may be alive, (yet to see evidence of it tho)
But the Spirit of "Elmering" is totally dead and gone I guess.
Users browsing this forum: infzqi and 7 guests
