It is currently Oct Wed 20, 2021 1:18 am
 Post subject: Panel shaft bushings?????????
PostPosted: Jan Tue 08, 2019 9:40 pm
I have tried to buy a couple of the little panel mount bushings which accept a 1/4 inch tuning shaft. I cannot find any on ebay, and I do not really know what to ask for. What is the correct name for these things? EX: If you wanted a pot or air variable cap to be at the rear of your radio chassis, you buy a 1/4 inch shaft, use a 1/4 inch coupler to mate the shaft and pot or cap, and put this 1/4 bushing through your front panel for the 1/4 shaft tp pass through and attach your knob onto. These are the same thing that are a part of every potentiometer. I do not know the name!
 Post subject: Re: Panel shaft bushings?????????
PostPosted: Jan Tue 08, 2019 11:10 pm
https://www.abbatron.com/products/92-panel-bearings
Brian
PostPosted: Jan Tue 08, 2019 11:23 pm
https://www.mouser.com/ProductDetail/Ke ... 8gxIL7WuXQ
Keystone is the company that makes all that hard to find stuff. They do not sell direct but through a distributor.
https://www.keyelco.com/category.cfm/Pa ... ngs/id/487
PostPosted: Jan Wed 09, 2019 12:35 am
Thank you all. I have tried to find these things on several occasions, and one time I did locate some, but I did not write down the name of the supplier. Thanks again.......William
PostPosted: Jan Wed 09, 2019 1:51 am
A panel shaft bushing can be made from most defunct volume controls or rotary switches. Just take them apart and apply a file...
YMMV
PostPosted: Jan Wed 09, 2019 2:00 am
Keystone makes everything.
Good quality American-made stuff. Download the catalog from their website.
Finding it may be a problem. Just persist, or send them an email and ask who sells item x.
Or try Mouser, Newark, or Allied.
www.mouser.com
www.newark.com
www.alliedelec.com
PostPosted: Jan Wed 09, 2019 2:30 am
I guess they call them "panel bearings", not bushings.
PostPosted: Jan Wed 09, 2019 2:48 am
If your in a bind, you can use the bush from a worn out pot. I save some repairs to have around when doing proto typing, so as not to waste good stuff till I build.
PostPosted: Jan Wed 09, 2019 5:56 am
Once I made one from a 1/4" headphone jack. Keep thinking outside the box.
PostPosted: Jan Fri 11, 2019 6:04 am
Yes, an old headphone jack works well. The Wells Gardner tuning shaft had a bit of play, but one turn of clear packing tape around the shaft tightened it up nicely.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Feb Tue 12, 2019 7:32 pm
I found that they are: ABBATRON 119 PANEL BEARINGS @ ARCADE ELECTRONICS for $0.82 each!!!!!!!+ shipping, about 5 bucks!
