It is currently Jun Wed 03, 2020 4:02 am
 Post subject: untuned rf amplifier for a regen receiver
PostPosted: Jul Tue 02, 2019 6:51 pm
I am building a regen, and would like to place a 12sk7gt tube, untuned rf amp between the antenna and detector tube. It seems to me that the signal could enter through a attenuator pot ,from the antenna post, to the grid of the 12sk7gt tube, and exit the plate of the tube,as an amplified signal,then, through a 4 pf mica cap. on to the antenna winding on the tuning coil form. From there, the signal would be induced to the tuning coil, and then on to the grid of the 12j5gt detector tube, after passing through the grid capacitor on the screen of the 12j5gt tube. If I have not lost you yet, could someone show a schematic of such an arrangement? Any help appreciated, and brother, do i need it!!!!!!william
 Post subject: Re: untuned rf amplifier for a regen receiver
PostPosted: Jul Tue 02, 2019 8:02 pm
I've done a bunch of them. I have found that the grounded grid RF amps do not help anything.
Simply putting the antenna on one end of a 5K pot and the ground on the other is of value. Feed the detector with a gimmick capacitor.
You do not want a high gain tube as an un-tuned RF amp. IT will be noisy. You want low gain. The point is to isolate the detector from the antenna. Using a pot an a gimmick cap does that fine.
Attached is an example of how I have done it.
PostPosted: Jul Tue 02, 2019 11:02 pm
Thank you Scott. I was pretty sure it could be done. What low gain tube do you recommend? Triode or pentode....William
PostPosted: Jul Tue 02, 2019 11:23 pm
Triode like 6j5, 6c6 or equivalent.
Mike Peebles added an RF amp to his 2-tuber, different but works well. He used a 1T4.
http://peeblesoriginals.com/catalog/manuals/PO-425.pdf
PostPosted: Jul Thu 04, 2019 12:55 am
typo? Triode like 6j5, 6c6 or equivalent. 6c5 maybe.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jul Mon 08, 2019 5:15 pm
Yes a typo.
6c5, 6j5, 6sn7, etc octal
6c4 miniature
try a medium or low mu triode. Hi mu tubes seem noisier
Users browsing this forum: LM386 and 6 guests
