It is currently May Fri 29, 2020 11:36 am
 Post subject: A most Pleasurable Amp SE6v6
PostPosted: Aug Thu 08, 2019 11:53 pm
A while back I decided to build a SE 6V6 amp. I patterned it almost exactly as one I found on line "Lacewood amp" (version 2)
http://www.cascadetubes.com/the-6v6-lacewood-amp-v2-0/
Here's my 33page thread about that build:
viewtopic.php?f=12&t=333779
Today I just wanted to update all of you amp lovers and report that after 10 months of careful listening and daily use, this fantastic and powerful little SE6V6 amp has really proven itself to provide wonderful continued HIFI listening pleasure.
It's physically small and simple to assemble in a small wooden box, as I chose.
Certainly metal is fine too.
It's just so easy and provides such powerful HIFI audio quality rewards.
Here's my final build box and schematic:
 Post subject: Re: A most Pleasurable Amp SE6v6
PostPosted: Aug Fri 09, 2019 3:30 am
Very nice work. I like it. Is that a repurposed box?
PostPosted: Aug Fri 09, 2019 6:28 am
Thank you very much.
No. I bought at Michael's store... Crafts.
Lot's of varieties to choose from only a few bucks each.
You can see a cpl other amps I built with wood boxes too.
http://www.pbpix.com/amp/
PostPosted: Aug Wed 14, 2019 4:07 pm
Very nice!
PostPosted: Aug Wed 14, 2019 5:07 pm
Hmm. Sorta like Fender Champ. X2
PostPosted: Aug Fri 16, 2019 2:21 am
Hi all. If you are into a single ended amp like this there is another tube you may like to work with and they are reasonable. I just put together a prototype push pull version 2 tubes. The 6AL11 or its family of 10AL11 and 12AL11 as well as 6T10 and 6AD10 and its filament cousins. The power output section is like a 6AQ5 and the other half a pentode can be used either triode or pentode mode depending on the gain you require.
PostPosted: Aug Thu 29, 2019 12:04 pm
Interesting. Would the circuit work with a separate heater supply and regulated B+? I have two 250 VDC @ 100 mA regulated power supplies originally used in series to produce just under 500 VDC for some section of an electron beam microscope. They are adjustable over a wide range and easily set up to provide the 300 VDC B+. The heaters in 12 volt configuration could be run off an Acopian hermetic 12V regulated supply I have on a shelf, that has been gathering dust alongside the two 250 volt supplies.
I would want to do the 12AX7 / 12AQ5 configuration.
Feasible? Thanks.
PostPosted: Aug Fri 30, 2019 2:50 pm
Feasible? Thanks.
Yes, they'll work. just reference them all to the same circuit ground (isolated from the AC supply).
Users browsing this forum: Dare4444, glue_ru, Tube Radio and 7 guests
