It is currently Jul Sat 11, 2020 12:15 pm
 Post subject: Long wire antenna
PostPosted: Sep Thu 05, 2019 6:35 am
Hello guys,
Well I have some questions about running a long wire first all one my ideas is run a long wire parallel with back of my house just under my over hang of my roof but bad thing is the local power poles run Parallel to but they are like 50 feet away .
The other way I thought was to run it from the back left corner farthest from the back door to the corner of my carport .
shown in the next picture but the first way would be less noticeable and not in the way
Sincerely rich
 Post subject: Re: Long wire antenna
PostPosted: Sep Thu 05, 2019 7:48 am
General guidance would be:
--Perpendicular to power lines
--As far as possible from power lines
--Not in a place where a falling power line could land on the antenna
PostPosted: Sep Thu 05, 2019 8:23 am
Or where a falling antenna could land on a power line.
PostPosted: Sep Thu 05, 2019 2:35 pm
Rich, W3HWJ wrote:
General guidance would be: ...
I would add, preferably at least 1/4 wave at the lowest frequency that you want to receive. It isn't a long wire if it isn't long.
PostPosted: Sep Thu 05, 2019 3:18 pm
Hello Dale,
Well the distance from my back of my house to my carport is about 50 feet
PostPosted: Sep Thu 05, 2019 4:24 pm
I think that was a fairly common length back in the day. A quarter wave at the low end of the AM band is un-attainable for most of us.
PostPosted: Sep Thu 05, 2019 7:02 pm
You got that right. For the low end of the BCB, 540 Kc, the antenna at 1/4 wavelength would have to be 455 feet.
http://www.onlineconversion.com/frequen ... length.htm
PostPosted: Sep Thu 05, 2019 10:30 pm
A true long-wire antenna needs to be multiples of one wavelength and will exhibit gain at the operating frequency. Anything less is actually a random length antenna. But most people have come to use the term pretty much interchangeably.
Darrell
Users browsing this forum: Google [Bot] and 10 guests
