It is currently Jul Tue 14, 2020 11:24 pm
 Post subject: Adding a tuned circuit to input of FM RF amp in table radio
PostPosted: Sep Fri 27, 2019 1:15 am
Many solid state AM-FM radios and cheaper stereo sets did not use a tuned LC circuit on the input from the antenna to the FM RF amp stage. Many such sets used those plastic cube miniature 4 gang tuning caps (2 for FM, 2 for AM). And as far as I can tell, none were made with 3 FM. But I figured out how to add a tuned circuit to the FM input. Find a 2 gang FM only plastic cube tuning cap (rare, so maybe just get another AM FM one and ignore the FM osc and the AMs). And build or modify a coil with a tap to be the L of the new LC circuit. Okay, now you have to do a mechanical linkage of some sort from the new cap to the existing tuning cap. 2 methods shown in the picture below:
The modified schematic:
The main difficulty in adding a tuned LC circuit on the input to the FM RF amp is to mechanically couple it to the rest of the radio's tuning mechanism. Initially, I mounted the new cap coaxially with the existing tuning cap. And I used a long screw to act as a pin attached to the new cap that in turn fits into a new hole in the tuning wheel mounted to the existing tuning cap. So when the radio is tuned, this pin also makes the new cap also get tuned. A kludge, but it worked reasonably well. I then decided on a more elegant method, mounting the new cap to the existing piece of circuit board I mounted the tuning knob to. And using a pair of same size tuning pulleys and dial string to couple it to the main existing tuning cap.
Looking at the bottom of the "new RF amp" schematic above, you can see the new FM front end RF amp input LC circuit. With the new variable tuning cap "C1K" (with its own trimmer C1M, and the coil LN are adjusted using a grid dip oscillator (GDO) to have it track the existing tuning cap. Tune in a station near the bottom of the band, tune the grid dip oscillator to "jam" that station, and adjust trimmer C1M to get the new LC circuit to resonate (which is when the GDO dips). Do that with another station midway in the band, and another near the top of the band. and iterate a couple of times. And adjust the inductance of coil LN a little, by spreading or squeezing the turns. The GDO's dial may be off, but jamming a station tells you you have the desired frequency dialed up on the GDO
FM station signal strengths increased on the FM band after I was done.
 Post subject: Re: Adding a tuned circuit to input of FM RF amp in table ra
PostPosted: Oct Sat 05, 2019 9:25 pm
Wow you really went to work on that, must be a nice radio.
Now that you've done this one, will you be doing more, or moving on to other challenges?
Edit: I see, you added an AM RF amp. Cool.
viewtopic.php?f=12&t=365546
Burl Ives, RIP, oldtimer.
[:l>)
