It is currently Jun Wed 03, 2020 4:36 am
 Post subject: Are there any RF tube amp experts out there?
PostPosted: Oct Fri 04, 2019 5:25 pm
Can anyone tell me in simple terms the path of a signal thru a 1x3 tube amp.
The mic is keyed and comes into the amp then where does it go.
Does it go to the transistor that engages the relays or does it go to the driving 6LF6 tube that then sends voltage to the output tubes which then engages the relay?
I'm trying to track down why the relays are not engaging but if I manually push the lower relay closed, the amp works and has output.
I'm not getting voltage from somewhere to engage the relays.
 Post subject: Re: Are there any RF tube amp experts out there?
PostPosted: Oct Fri 04, 2019 6:07 pm
Input is a mic with push-to-talk? Usually, the push to talk is simply a push button switch that completes the circuit to energize the relay. It could be directly or it could be through a 'buffer' of some kind. Would need to see more of the circuit to make any more detailed suggestions.
What has this got to do with RF?
PostPosted: Oct Fri 04, 2019 6:12 pm
It's an RF amplifier
Let's ignore the pictures and tell me simply how does the signal travel through a simple 1 transistor with 1 driving tube and 3 output tube?
PostPosted: Oct Fri 04, 2019 9:26 pm
Provide a schematic an I'm sure some can help you. Help us help you.
Jason
N1EBC
PostPosted: Oct Fri 04, 2019 9:36 pm
Thanks for the reply but this one is homebrew and no schematic was ever drawn.
PostPosted: Oct Fri 04, 2019 9:55 pm
Most likely, the input is applied to the control grid of the driver tube. Output taken from the plate. The outputs could be either common cathode with the signal applied to the control grid, or grounded grid with the input signal applied to the cathodes. In either case, the output comes from the plates into an impedance matching network (often a pi network) and feeds the antenna port.
PostPosted: Oct Fri 04, 2019 10:32 pm
Thanks Ylli.
do you know where the transistor comes in to play?
Is it during input or output?
PostPosted: Oct Fri 04, 2019 10:35 pm
It appears to use RF sensing on the input to key the change over relays. I think I see a detector diode near the so-239.
PostPosted: Oct Fri 04, 2019 10:40 pm
Peter .... can you describe it to me?
is it the clear what I thought were transistors?
PostPosted: Oct Fri 04, 2019 10:44 pm
A linear with a driver tube is usually designed for illegal CB use. Do you have a ham license?
DM
PostPosted: Oct Fri 04, 2019 10:49 pm
Of course and none of your business !!!
PostPosted: Oct Fri 04, 2019 11:11 pm
A little snippy aren't since YOU are asking for help.
How about trying to sketch out a rough schematic it will only help your learning.
Jason
N1EBC
PostPosted: Oct Fri 04, 2019 11:15 pm
I apologize because I meant it jokingly and after i read it , it does sound rude. Sorry
PostPosted: Oct Sat 05, 2019 12:06 am
Trying again:
1. Did you fix the broken transistor referenced in the previous posting on this amplifier?
https://antiqueradios.com/forums/viewtopic.php?f=12&t=365188
2. Does the schematic below correlate with your unit? (6LF6 can substitute for EL509 with mods)
PostPosted: Oct Sat 05, 2019 12:42 am
Macrohenry .... thank you. I did replace the transistor but no data sheet is available for a 2n600 to know which is emitter, base and collector so I tied it in the same as the old one. I'm thinking the collector should go to ground. I'm not sure
I am studying the schematic and will be back to you shortly or tomorrow because I have some errands to run.
I started this new thread because I was asking a different question.
Thank you
PostPosted: Oct Sat 05, 2019 2:48 am
2n600 or a 2n6000
2n6000 is a NPN
How to identify transitor pinout with a multimeterhttp://www.electricalbasicprojects.com/how-to-identify-npn-and-pnp-transistor-using-multimeter/
Jason
N1EBC
PostPosted: Oct Sat 05, 2019 9:18 pm
Remember this for next time - to ask a new question about the same unit, go back to you very 1st post, Edit, then change the title of the post. These experts are smart enough to go to the last post, where they find the latest info.
All one thread keeps the history of the unit before the new question without searching for it or having to ask for details.
#2, If you make a 'possibly snarky' response, be polite, and say it with a smile. :lol:
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Oct Sat 05, 2019 10:50 pm
Thanks WestCoast for the advice. I Will heed that.
PostPosted: Oct Sun 06, 2019 11:39 am
The 2n600 is a pnp ger from what I could find. 2n600 looks like a bolt.
Machenry.... the schematic is similar but more components than what I'm trying to repair so I'm having difficulty trying to follow the path.
PostPosted: Oct Sun 06, 2019 2:05 pm
Transistor pinouts there is one with a stud in the pic
http://www.radio.imradioha.org/Images/Base_Diags.jpg
Jason
N1EBC
Users browsing this forum: philcotube and 16 guests
