It is currently Mar Sun 29, 2020 3:44 pm
Post New Topic Post Reply  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Working on a AM transmitter prototype
PostPosted: Oct Fri 18, 2019 7:24 pm
Tube Radio wrote:
maximum voltage for the TCXO is not exceeded.
To nitpick, that looks like just a simple crystal oscillator, not one that's temperature compensated.
And no, that has no relevance to your comment, which would apply to anything that's designed to run off 5V.
Michael
PostPosted: Oct Fri 18, 2019 10:38 pm
Could be just regular oscillators.
PostPosted: Oct Fri 18, 2019 11:05 pm
I used a simple oscillator for this experiment.
PostPosted: Oct Fri 18, 2019 11:10 pm
Yes it is.
PostPosted: Oct Sat 19, 2019 2:02 am
I would think 9 volts would be a bit much as I'm sure the transformer doesn't drop 4 volts.
PostPosted: Oct Sat 19, 2019 3:44 am
Hello Paws,
what great idea hope everything works out for you .
super cool thou and I have one sstran3000 transmitter .
Well azenithnut,
I took used that trainer and remember the circuit I still have my heathkit trainer book I was thinking of scoping ebay for one those old trainers .
Anyway Wazz ,
I like your idea what unit are you using ?
Sincerely Rich
PostPosted: Oct Sat 19, 2019 3:42 pm
Version of LM386 xmitt. Will transmit 50ft or more.
viewtopic.php?f=12&t=345493
PostPosted: Oct Sat 19, 2019 7:43 pm
radiorich wrote:
Well azenithnut,
Sincerely Rich
Oh you took that course too? We followed it exactly except for the Microprocessor course. We switched to Intel rather than follow Heathkit with Motorola.
This is the circuit trainer we used.
PostPosted: Oct Thu 31, 2019 10:28 am
Here is the completed unit. I was able to put approx 70hrs of old broadcasts on the player with room to spare. I hooked the leads directly to the Antenna/Ground connections. Came in load and clear.
