It is currently Aug Mon 10, 2020 1:17 pm
 Post subject: High Voltage Switch Mode Power Supply
PostPosted: Dec Wed 11, 2019 10:15 am
Hi Forum, On my power supply this is a connection for an on/off switch to add, there is also an LED on the board to show power is on. I installed the switch and when power is applied the LED is bright green, but I place in the switch in the off position there is a faint green glow. Can anyone shed some light on this problem?
Thank You, Tony
I Love The Warm Smell Of Tubes In The Morning
 Post subject: Re: High Voltage Switch Mode Power Supply
PostPosted: Dec Wed 11, 2019 10:36 am
You didn't wire the switch correctly, unless the LED is supposed to remain on dimly, to indicate that power is connected.
PostPosted: Dec Wed 11, 2019 10:42 am
Hi. Thank You for help but It's a simple SPST switch and there is a post on the PCB to install a switch? You might be correct that the dim LED does show power connected?
Tony
PostPosted: Dec Wed 11, 2019 10:44 am
One how question how do I add the cool comments that you folks have after on-screen information?
Thank You
PostPosted: Dec Wed 11, 2019 11:12 am
You have to be one of us cool heads... :wink:
PostPosted: Dec Mon 16, 2019 4:07 am
Thank You
It's called your "Signature", in your profile.
