It is currently Feb Tue 25, 2020 10:40 am
 Post subject: best sw antenna
PostPosted: Dec Fri 27, 2019 3:12 pm
has anyone tried this antenna ? if so , did you like it ? did it work for ssb ? …………. thanks .. steve
MLA-30 Loop Antenna Active Receiving Antenna 100kHz-30MHz for Short Wave Radio
8r40
 Post subject: Re: best sw antenna
PostPosted: Dec Fri 27, 2019 3:38 pm
Where is that blurb from? If it was something like EBay. then post a link.
In general, the best antenna is the one you have room for. The most important parameter is aperture...with higher frequencies--up to light-- it's typically the area--eg the "size of the hole in front of the camera". With the lower frequencies, it's length---eg the ubiquitous "long wire"
For something like the BC band, read any of the many threads here about loop antennas.
-Mark
PostPosted: Dec Fri 27, 2019 6:42 pm
If I'm not mistaken the MLA-30 is based on...
Charles Wenzel's Active 3-30 MHz Hula-Loop Antenna for Shortwave...
http://www.techlib.com/electronics/antennas.html
PostPosted: Dec Fri 27, 2019 7:06 pm
thank you for the link ………. im learning slowly . ham radio is just … 1) beam 2) power
8r40
PostPosted: Dec Fri 27, 2019 8:25 pm
Good insight...
Here is what I have always called the "antenna equation":
P(received) = P(transmitted) * (A1 * A2 / R^2)
A1 and A2 are the areas of the transmitting and receiving antennas, and R is the distance between them.
The equation is valid at the higher frequencies (including light) where antennas tend to be flat circles, ovals, etc.
For the lower frequencies, I'm sure there's an "equivalent area"
-Mark
PostPosted: Dec Sat 28, 2019 1:35 am
insite ??? just mo power ………..
8r40
PostPosted: Dec Sat 28, 2019 1:48 am
-Mark
PostPosted: Dec Sat 28, 2019 4:15 am
more power from amp
8r40
PostPosted: Jan Sat 25, 2020 6:48 pm
still checking on swl antenna . is there better than what I have ?
mla-30 @ 30' with rotor ………… any ideas appreciated ………… steve
8r40
8r40
PostPosted: Jan Sat 25, 2020 6:57 pm
KZST Santa Rosa ???
Are you seeking a transmitting antenna? Loops and "active antennas" are usually used for receivers. MFJ sells transmitting loops, but beware the high voltages necessary with such compromises.
The fun experience of ham radio is about learning, not buying "mo power."
PostPosted: Jan Sat 25, 2020 7:15 pm
receiving only . just using left overs from ham ……….. thanks... steve
8r40
PostPosted: Jan Sat 25, 2020 7:53 pm
OK
Adding "mo power" to a receive antenna.... adding a high gain amplifier as most "active" antennas do, can mean just amplifying noise. A good tuned loop will "peak up" what you want to hear, and lose some of the "noise." It is also directional.
http://kr1s.kearman.com/html/hooploop.html
PostPosted: Jan Tue 28, 2020 2:11 pm
Best Short Wave Antenna ?
I found out the answer to this question unexpectedly after research on transmitting antennas.
I was comparing loop antennas to whip antennas over the range of 1MHz to 30MHz. This involved a variety of loops and wire antennas, looking at the EM radiation mainly in the near field. Of course, as is mostly the case, a good radiating antenna is also a good receiving one.
So, for the whip antenna I started out with a tune-able antenna from Tarheel in the USA. These were made to be mounted on cars, where the car, to an extent, acts as a ground plane. They have a motor adjustable loading coil to tune them.
So I manufactured another type of ground plane with a large octagonal plate and long radial rods made of 1 cm square section aluminum and fitted the antenna to the corner of my house (see attached photo). The ground plane is also Earthed. (That blimp in the photo just happened to be there and ignore the VHF antenna on the mast)
As a receiving antenna is unbeatable on the SW band and out does all of the other antenna variants I tried. Also as a transmitting antenna, say on 1.4MHz, with a mere 50mW of power the transmission range is astonishing, some hundreds of meters. Though I do not use it for this application, just short wave reception now, but it was an interesting research project.
PostPosted: Feb Thu 20, 2020 4:04 am
Rich, W3HWJ wrote:
OK
Robert White
Ottawa, Ont. CANADA
fm453@ncf.ca
