It is currently May Wed 27, 2020 3:37 pm
 Post subject: A single valve 9VDC Am Xmitter
PostPosted: Jan Thu 02, 2020 10:03 pm
Dear forum.
Some time ago I received a box with several valves in it. Most were not so interesting, however, I did find a few ECH83 and ECH81´s in it. Now what could be built with that? Since I have a few valve-radios, and a single AM-only radio, I thought building an AM-Xmitter at low voltage. Could this be done? The ECH83 is defined at low voltages, A heptode/triode mixer for carradio´s.
So I read a few articles about the ECH83, about antenna theory and experimented with a homebrew Xmitter. Since that proved successful I thought to share it. Bought a few empty coil shells, designed a circuit board.
The inductor (actually transformer) was -for me- the hard part to get. I ended up making my own. I found an empty shell inductor base. The empty shells -with core- were too short for this application (I want 1MHZ, the shells are for 25Mz>). So I glued two together and wire wound a transformer.
I added a 2 meter (i.e 6 feet) antenna. I can receive the transmission at all my AM radio´s in my house.
The schematic has a few optional components. i used a voltage regulator for the filament voltage, but a 10 Ohm resistor (>1Watt) will do. The antenna output circuit is also optional, however you will need some impedance matching. I omitted L1 C8 C12.
The oscillator circuit is slightly critical at low voltages, so I deviated from the original Philips circuit. Lowered R4 to 12k and C2=100p instead of 47p. That doubled the oscillator voltage.
Pls look at the circuit, and if you have any comments or improvements let me know....
File comment: Empty shell
File comment: Setup
File comment: let´s call it the Beach II
 Post subject: Re: A single valve 9VDC Am Xmitter
PostPosted: Jan Sat 04, 2020 12:19 am
How much audio signal is required for full modulation?
PostPosted: Jan Sat 04, 2020 1:30 am
Good question.... I will need to measure that. As in the pic (2) I used an MP3 player. Connected the headphone output to the AM transmitter input.
I will get back to this...
PostPosted: Jan Sat 04, 2020 5:49 pm
So I connected a sine wave at the junction of R1/R2/C10. At approx 400mVtt (140mV rms) I get 100% modulation. This might be adjustable by changing R10, but I did not test that.
PostPosted: Jan Sat 04, 2020 9:47 pm
Oh ok cool.
Interesting design though in that an audio preamp tube isn't needed at all.
PostPosted: Jan Sun 05, 2020 7:08 am
Clever use of an interesting tube. Simple circuit. 8)
https://www.radiomuseum.org/tubes/tube_ech83.html
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Jan Sun 05, 2020 8:05 am
If you know anyone with a spectrum analyzer, get them to check
whether is creates any parasites in the commercial aircraft band.
You don't want your music to be heard in a plane flying directly overhead.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Sun 05, 2020 4:31 pm
I'm yet to see any tube produce enough signal at 9v to be detectable across a small room. The typical crystal osc at 5v can produce a signal that travels at least 15-20x farther.
PostPosted: Jan Sun 05, 2020 11:05 pm
The tube is one designed for 12 volt plate voltage if that makes any difference.
PostPosted: Jan Sun 05, 2020 11:34 pm
It is what I did not see in the schematic that made me wonder. Like
how does it oscillate?
The output, power is needed.
Could it be 0.4 watts ?
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Mon 06, 2020 3:15 pm
For use in the US you need to measure the plate voltage and current (with no modulation) of the final tube. The product must be no more than 100 mW for legal operation in the US.
https://plymouthcolony.net/starcityeng/index.html
PostPosted: Jan Mon 06, 2020 4:38 pm
And A Partridge In A Pear Tree.....
PostPosted: Jan Mon 06, 2020 5:55 pm
I doubt he's pulling even so much as 1mA plate current and at 9V that would be less than 9mW.
PostPosted: Jan Mon 06, 2020 8:51 pm
The OP reports that he can hear his transmitter on all the AM radios in his house. After fifty years in broadcast engineering I can assure you that he is well in excess of 9 mW.
PostPosted: Jan Mon 06, 2020 9:52 pm
Maybe he has a really small house. :wink:
Btw, it he's putting out 100mW then he's exceeding the max allowable cathode current by almost 300%.
PostPosted: Jan Mon 06, 2020 11:04 pm
It really looks like a nice project. Knowing the 9 volt
current levels on the three pins that feed it, as well
as what happens if any very high level audio, or any
AC signal gets in via the stereo jack, is of interest.
Interesting read:
May 22, 2003 - Although the monitor was designed to work at
a frequency of 49MHz, a fault made it broadcast at the
restricted air traffic frequencies of 108-136MHz. It can easily
happen, says Tony Maddocks of ERA Technology in Surrey,
which recently assessed the threat of interference from
radiowaves to London's air traffic.
Interesting read:
https://www.theguardian.com/science/200 ... equestions
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Tue 07, 2020 2:44 pm
Here´s the OP. My house is some 30*40 feet.
I don´t have equipment to measure the power output, however from the datasheet:
Heptode as a mixer:
Ia = 50uA @ 6V3
Ia = 170uA @ 12V6
Let´s say at 9V it draws 100uA, according to the US regulation you´d have 9V*2*100uA = 1.8mW output power AT MAX.
However, IMHO, that is a toptop value, RMS would be 1.8mW/2/sqrt(2) = 640uW. And that is if it actually would output 18Vtt.
It is more like 1Vtt, maybe 2Vtt max.
2Vtt--> 70uW
And finally, at best half of this is radiated through the antenna --> 35uW.
Are my calculations correct so far?
PostPosted: Jan Tue 07, 2020 4:55 pm
Can you measure the current in the VCC line with a DVM line when the transmitter
is working broadcasting a tone, of 400 Hz. How many volts AC is the
signal fed into the audio jack ?
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Wed 08, 2020 5:13 pm
I would like to oblige, however that would mean breaking down my PCB and solder work..... And I had to cannibalize my original experimental setup, so I´m afraid I cannot answer this one.
PostPosted: Jan Wed 08, 2020 9:30 pm
The dual aerial system is interesting. How long are these aerials ?
I you were to modulate your transmitter at a frequency of, 120 kHz
with a low cost function generator, do you think the signal would be
picked up on a common ham radio receiver ?
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
