It is currently Sep Wed 23, 2020 9:10 pm
 Post subject: iPod Amplifier built from 1920's components.
PostPosted: Jan Mon 20, 2020 9:10 am
A while ago I came across some Samson brand 1920's vintage audio transformers. They inspired me, so I decided to craft them into an amplifier, see attached picture.
The physical construction consists of a pre-painted steel Hammond chassis, the front panel material came from the Luthier's suppliers. I tried to keep it as simple as possible, yet with the art & styling of 1920's electronics.
I was very interested to investigate the the calculations for the ideal plate to plate resistance for a class AB1 push pull amplifier, rather than just the graphical approach.
I found after researching the topic that a lot of the work in this area was done by the staff at MIT.
Very early in the piece, the benefits of push pull in terms of reducing the tube's dissipation and generating more power at the same time were not recognized, in fact RCA initially recommended running valves in push pull in class A mode, making it look somewhat unattractive to a designer. I have explained a lot of the technicalities in this article:
http://worldphaco.com/uploads/UX-171-A_ ... ifier..pdf
Of note it is important when working with pre-painted steel chassis to smooth & paint the cut hole edges, or of course they will rust later.
 Post subject: Re: iPod Amplifier built from 1920's components.
PostPosted: Jan Mon 20, 2020 2:49 pm
I like the styling and application. I built a tube based amp for my ipod but it is not vintage style and not near as attractive as yours.
You do good work. We love functional eye candy.
PostPosted: Jan Mon 20, 2020 2:50 pm
Nice work !!
PostPosted: Jan Mon 20, 2020 3:59 pm
Very nicely done!
Your attention to detail, both technical and mechanical, is inspiring.
73, de Chuck K4CCW
PostPosted: Jan Mon 20, 2020 4:44 pm
That is a very attractive project. What did you do to the back of the speaker? Is that a cover you added?
Paul
...... how hard can it be?
PostPosted: Jan Tue 21, 2020 12:21 am
It was a shielded speaker magnet type, I found a piece off copper water pipe that was almost the same internal diameter as the magnet. I had to machine it out (the inside) about 0.3mm to get a short section of it to just slip over the magnet. I made it long enough to just house the impedance matching transformer that I designed and wound to go in that space. The end of the pipe then had a thick machined phenolic disc which is retained by small screws and has the thumb nuts/connections on it, to sort of give the speaker an older look.
(It is quite tricky to machine copper and it requires a lot of lubrication)
PostPosted: Jan Tue 21, 2020 12:30 am
Very nice look. You obviously have skill and patience.
Paul
PostPosted: Jan Tue 21, 2020 1:28 am
Thank you for the kind remarks.
Of course it is always possible to go over ornate. A good example would be the design of the Time Machine from the movie in the 1960's with Rod Taylor. It had a lot of plush velvet like material and gold domed studs etc. The best description I ever heard of it was: "It looks like something Elton John would have driven through the Everglades ".
The Time Machine from the second movie (with Australian Actor Guy Pearce) was better, it looked like it was made with Fresnel lenses from a lighthouse and had what looked like a Babbage Analytical Engine as the control console. Lots of Brass and Crystal.
PostPosted: Jan Fri 31, 2020 4:42 pm
Very pretty, Acorn.
PostPosted: Jan Fri 31, 2020 5:10 pm
I am envious of your visual style and building skills. Beautiful workmanship! It cannot be compared to my own, which seems to be stuck in a childhood cigar box phase.
-Richard
PostPosted: Feb Sat 01, 2020 12:15 am
Thanks for the kind remarks about this amplifier.
In the article about this iPod amp I put a link to, on the original post, there is a real gem hiding in it, for audio enthusiasts.
I wondered if anyone would pick up on it. It is a remark about second harmonic distortion in class A amplifiers (based on pentode tubes) where there is a function available not possible with a Class A transistor amplifier stage, though the knowledge of this is not common in the Audiophile industry I have found, as it appeared in very few textbooks in the tube era:
"It is possible run a single pentode in class A operation with the correct load
resistance for zero second harmonic distortion. This is not physically possible with a
class A transistor. The method of how to do this is outlined on page 553, Sec 18-5,
Electronics Devices & Circuits, Millman & Halkias 1967, McGraw-Hill".
Actually it is an excellent book and worth buying, just for the section that explains this, but also for anyone interested in tube or solid state design.
PostPosted: Feb Mon 03, 2020 5:07 am
Those transformers found a good home where they'll be admired for years to come. Good job!
Burl Ives, RIP, oldtimer.
[:l>)
Users browsing this forum: No registered users and 14 guests
