It is currently Oct Tue 20, 2020 4:11 pm
 Post subject: Variable capacitor mounting
PostPosted: Jun Tue 23, 2020 7:39 pm
I have quite an abundance of tuning capacitors from scrapped radios mostly aa5's . I would like to use them for my different regen.projects but the problem is most of them were circuit board mounted. They have the nice triangular pattern of holes but they are not threaded. It would be quite hard to get a screw and nut in there,close clearance ! Would a thread cutting screw work and what size do you think?
 Post subject: Re: Variable capacitor mounting
PostPosted: Jun Tue 23, 2020 7:53 pm
A thread cutting screw, or a tap carefully used. You have to take precautions to keep the chips out of the plates and the ball bearings.
Most were either 6-32 or 8-32, you can tell by the size of the unthreaded hole which it was intended to be.
PostPosted: Jun Tue 23, 2020 8:28 pm
You may need a bottoming tap, depending on the amount of clearance between the hole and the stator:
https://en.wikipedia.org/wiki/Tap_and_die#Tap
McMaster-Carr is one source:
https://www.mcmaster.com/bottoming-taps ... teel-taps/
PostPosted: Jun Tue 23, 2020 8:59 pm
If you buy a tap, (from my experience) buy the absolute best quality taps you can afford (or better). Also buy a properly fitting tap handle .... emphasis on "properly fitting". The first time you break a cheap tap off in an attempt to cut threads and you are stuck with broken tap in a good capacitor, and it happened because you had a cheap tap or were driving it with the wrong tool, that's when the better quality tap and handle set would have paid for itself.
PostPosted: Jun Wed 24, 2020 6:50 pm
Yes, tap the holes for 6-32. I think the correct drill bit is #35. Use a little bit of machine oil and go slow. 8-32 may be overkill.
PostPosted: Jun Thu 25, 2020 1:48 am
I have made brackets that I bolt or screw to new holes I drilled on the back or front of the capacitor then fastened the bottom of the bracket to the chassis or board.
The new holes are made where they will not interfere with the capacitor plates.
Lee
If you can't figure it out, cool the iron and start your day over.
PostPosted: Aug Thu 06, 2020 7:02 am
Thread is 6-32. I bought a tap and tap the hole as long as the tool goes. From experience, the hole is able to receive a screw with this initial thread - actually the screw does the rest of the job. You can try buying a second tap and snap off its tip, so that you can use it to finish off the thread.
PostPosted: Aug Thu 06, 2020 12:18 pm
...You can try buying a second tap and snap off its tip,...
NOW, you have a bottoming tap.
I refer you to Steve's WIKI LINK. Good info for those who haven't used taps before.
Taps, by necessity, have to be quite hard, and are thus brittle. Machine screw taps, by virtue of their small size are therefore fairly easily broken. So, when using them be aware of how much torque you are applying, AND make sure you don't "wobble" as you're rotating it.
I have one of these I bough probably 40 years ago and it is still a handy tool. By being a screw driver format as opposed to the typical lever handle type, it reduces the danger of you breaking a tap.
TAP DRIVER
For those who do a lot of building I've found that using small battery powered drill drivers is a real step up. The Fwd/Rev bar which is usually conveniently located, makes the in/out of tapping quick and easy, while the clutch minimizes, and for #6 and larger, eliminates the possibility of breaking a tap because of torque.
