It is currently Oct Sun 25, 2020 6:08 pm
 Post subject: DDS transmitter
PostPosted: Jul Tue 28, 2020 12:53 pm
Has anyone here built a DDS transmitter for AM low power broadcasts?
 Post subject: Re: DDS transmitter
PostPosted: Jul Tue 28, 2020 11:20 pm
This isn't a complete transmitter, but a number of forum members have used this as the exciter for some of the various transmitter projects that have been posted on the forum.
viewtopic.php?f=12&t=82833&start=0
Also, I've used an AD9851 as the frequency source for a one tube transmitter.
PostPosted: Jul Tue 28, 2020 11:58 pm
https://www.antiqueradios.com/forums/viewtopic.php?f=12&t=82833&start=0
$12 MW Frequency Generator for Part 15 transmitters
Not exactly what you asked for, but may be what you need.
This is good for driving an AM modulator stage.
Ted
PostPosted: Jul Wed 29, 2020 12:30 am
Thank folks. I was think more inline with these things you can buy on ebay but homebrew instead..
https://www.ebay.com/itm/AM-MW-RADIO-BA ... Sw5EdbHBmA
Steve
PostPosted: Jul Wed 29, 2020 11:22 am
$160 sure is a LOT of money for what it is, but, if you're incapable of, or just don't want, to alter a far less expensive DDS, what you suggest, is an option.
There are DDS units for 25 bucks out there, which can be easily modified for A.M. operation.
PostPosted: Jul Wed 29, 2020 10:49 pm
thats what I was looking for .. the plans from others that may have already done it.
PostPosted: Jul Thu 30, 2020 9:52 pm
You need to be aware that even if you have some sort of digitally tuned transmitter, you can't simply punch in a frequency and expect it to put out a signal having any significant range, without also tuning the antenna. I haven't yet seen any hobby grade DDS transmitter that can do that. So, the antenna tuning is still going to be a manual adjustment.
It would make for a very interesting project to develop an automatic antenna tuner for a Part 15 transmitter.
PostPosted: Jul Thu 30, 2020 10:46 pm
high bob. Ya that exactly the kind of stuff that i was hoping someone had already done. Modulating, amplifying, matching, etc.
PostPosted: Jul Thu 30, 2020 11:15 pm
Frequency generation, modulation and amplifying has already been done many times and in many different ways. You can mix and match the sections as you like.
Antenna matching still remains a manual adjustment as far as I'm aware, but an automatic matcher should be doable. These units exist for amateur radio equipment.
