It is currently Oct Sun 25, 2020 5:26 pm
 Post subject: reflex radio question
PostPosted: Aug Wed 05, 2020 5:10 am
I recently built a vintage reflex radio from a kit, it uses 4 germanium PNP transistors and a germanium diode. after some tweaking I was able to tune the whole band and the radio sounds normal as long as the volume is low, if I turn the volume up past a certain point the radio will squeal until the volume is lowered fully. I don't really understand fully why it does this and i'm not sure if it's normal for the design of this radio or maybe I did something wrong. R3 is the volume knob and R1 is the feedback control I think, i'm not really sure how to set R1. I appreciate any feedback! the kit is a Yunost' KP101 by the way, it was quite fun to make!
 Post subject: Re: reflex radio question
PostPosted: Aug Wed 05, 2020 4:39 pm
Make sure C8 is installed with correct polarity. Positive mark on cap goes to ground (common).
The internal resistance of the battery will sometimes enable audio feedback. Especially if you need to draw some current at high volume.
PS: I would have used about 100 uF at C8.
PostPosted: Aug Wed 05, 2020 7:56 pm
If yu used vintage caps you may need to replace them with new ones . The ESR may be too high with the ones you have .
Mark
PostPosted: Aug Wed 05, 2020 10:08 pm
I found instructions here, it's surprisingly complicated. I had to wind transformer T1 by hand. the instructions say to wire it up temporarily and test the receiver but i didn't do that. also there is lots of experimentation involved with the feedback and coupling coil. https://www.radiomuseum.org/r/moscdevice_junost_kp101kp_10.html
PostPosted: Aug Wed 05, 2020 10:38 pm
i fixed it, the primary of T1 was backwards. thanks for the input guys!
Users browsing this forum: Mike Toon and 6 guests
