It is currently Oct Sun 25, 2020 6:00 pm
 Post subject: Am Loop antennas
PostPosted: Aug Fri 21, 2020 3:15 pm
I'm restoring a Delco R 1218 the loop antenna is just fine. but being the curious person I am I got to poking around on the net and I know you can purchase Loop antennas. And I found plans to build large loop antennas. But has anyone tried to build one of the small Loop antennas like the ones that come in the All American 5 and All American 6? I don't need one for my set I would just like to see if I could. And what it would take. Thank you.
 Post subject: Re: Am Loop antennas
PostPosted: Aug Fri 21, 2020 7:33 pm
I'm sure people have built their own loop antennas to replace missing ones on radios that originally had one. I'm equally sure that there are plans on the internet for building them.. I just cut a pattern of the size I needed out of cardboard, then cut out an odd number of tabs around the perimeter. Then I wound magnet wire around the perimeter and in and out of the tabs until I got the appropriate inductance. An inductance meter is really handy for this. I just used trial and error until I got it to work with the tuning capacitor. There are formulas out there for calculating the inductance of a coil, but there are also a number of variable.
PostPosted: Aug Fri 21, 2020 7:38 pm
You can find the instructions for building spider coil antennas on this site: http://makearadio.com/coils/spider.php
You will need something like one of the $20 capacitance meters to measure the range of the tuning capacitor you will be using.
https://www.ebay.com/itm/Capacitor-Test ... 2762693353
For about $15 more, you can get a meter that also measures inductance.
Litz wire gives the best performance and can be found on Ebay.
Regular solid wire is used on most AA5 loops and works OK.
Jay
PostPosted: Aug Fri 21, 2020 9:48 pm
Spacing helps I found out.
PostPosted: Aug Fri 21, 2020 9:59 pm
A Heathkit RLC bridge will do both.
https://www.ebay.com/sch/i.html?_from=R ... =1&_sop=15
PostPosted: Oct Sun 11, 2020 11:45 pm
I see the loop you built has a winding for an external antenna and I was wondering how you wound it. Did you add it after you had finished the main winding or did you wind it along with the last few turns of the main winding? Seems like it would be hard to add afterwards. How many turns did you add for the external winding?
PostPosted: Oct Mon 12, 2020 12:23 am
I copied an AA5 antenna with wire I had on hand on Masonite I cut on my bandsaw.
It didn't receive quite as well as the original so I figured it was wire size and spacing being the only difference. I'm sure I could have adjusted the var cap to compensate but I left it as it was. I did wind an additional loop but it wasn't needed on the original. It was just an experiment for another radio.
PostPosted: Oct Mon 12, 2020 7:02 pm
Thanks Mike. Here's one I built using the formulas at http://makearadio.com/coils/spider.php and was thinking about adding a few turns for an outside antenna hookup.
I used 20 gauge magnet wire (.0334" dia). The inner diameter of the loop is 5". And I wound 29.5 turns. The formula said that would result in an inductance of 224uh. Messy as my attempt looks, it actually came out to 228 uh's.
The var cap in the radio I installed it on has a range of 22 to 470pf. I figured a 224uH loop might be about right. The radio plays really well. It ended up with a range of 533 to 1498khz. So, a little low at the high end. Might be able to raise it enough when I align it, otherwise maybe add a turn to the coil.
C4 Wire diameter Input this value
C5 Number Turns Input this value
C6 Inside Diameter Input this value
C7 Coil Depth (C4*C5)
C8 Mean Radius (C7+(C6*0.5)+(C6*0.5))/2
C9 Outside Diameter (C7*2)+C6
C10 Inductance (((C8*C5)^2)/((8*C8)+(11*C7))) [The main formula]
C11 Wire Length (C5*C8*2*3.14)/12
I found a round loop was easy to lay out, although it might be too tall to fit some cabinets. You need an odd number of cutouts so each winding alternates tabs with the previous winding.
PostPosted: Oct Mon 12, 2020 7:43 pm
Using a CD plastic protector.
Users browsing this forum: No registered users and 14 guests
