It is currently Oct Sun 25, 2020 6:04 pm
 Post subject: Even Simpler Barebone AM TX
PostPosted: Aug Mon 31, 2020 8:20 pm
Even simpler bare bone TX.
One switch used as oscillator and another as modulator. Third one is left unused. It was tested with a 1MHz crystal several years back. A LPF is recommended to filter out the harmonics.
It is a cool design! Use LM386 at a slightly higher voltage to feed the voltage divider. 3Vpp will result in 100% modulation
 Post subject: Re: Even Simpler Barebone AM TX
PostPosted: Sep Tue 01, 2020 2:39 am
Sorry. I'm confused again by your pin numbering.
Doesn't Pin 6 have to be grounded to enable the switches? Also what state should Pin 7 be in?
Neither is shown on your schematic.
Have you gotten your computer fixed yet?
Another question. Why can't the output of the LM386 if run from the same 5V supply be connected directly to Pin 3?
PostPosted: Sep Tue 01, 2020 5:29 am
Both pins 6 and 7 should be grounded. LM386's output can be connected directly but its ouput doesn't swing all the way down to 0V. It's necessary to achieve 100% modulation. So driving a voltage divider with LM386 is better. With LM386, 85% modulation is the limit at 12V but with the divider 100% mod depth is easily obtained. Distortion is also low and sound quality is on par with expensive AM Transmitters.
PostPosted: Sep Tue 01, 2020 5:51 am
Why not use the unused switch Pins 11, 12 and 13 to improve the efficiency and the modulation percentage?
PostPosted: Sep Tue 01, 2020 6:22 am
It might increase input power beyond 100mW FCC limit so I played the safe side. I'll have to experiment again to check input current and output power levels but I have crystal in the range of 6.4 to 30MHz which I think should work fine with the HC version of 4053. It can also be clocked with a CD4060, 20MHz XTAL giving 1.25MHz output
PostPosted: Sep Thu 03, 2020 7:12 am
I forgot to mention that both switches have been used for the oscillator part. The remaining one is the modulator. I connected output of lm386 directly to pin 3 and tested the circuit with a 10MHz xtal. Output power is 6mW without LPF into a 47ohm load. Modulation quality is good but range is gonna be limited very limited. I'm getting a few feet with 10 feet wire ant at 10MHz.
Modifications needed. We need to separate the oscillator section and use the whole chip as a modulator. Plus LPF also required at the output and if the modulation is asymmetrical then a complimentary pushpull RF amp would be needed.
PostPosted: Sep Thu 03, 2020 11:06 am
I wired up this circuit and connected a 10 ft. wire antenna for testing. Range is 10 feet. Lowering the crystal frequency from 10MHz to 7.2MHz made it work without instability. So I guess it will work just fine with a lower frequency crystal, say 1MHz. Audio was distorted at 10MHz. The two feedback capacitors need to be increased to 33p for 1MHz crystal. Total DC input to pin 1 of 7805 is 15ma at 12V. It means the chip is drawing less than 100mW at 5V! A 7 pole LPF and antenna matching network should be added for maximum range. Sound quality is great!
PostPosted: Sep Thu 03, 2020 4:11 pm
Holy solder blob, Batman! :shock: :lol:
