It is currently Dec Thu 02, 2021 10:48 pm
 Post subject: One FET Regen
PostPosted: Mar Tue 11, 2014 3:22 am
Here is my design of a one fet regen. It has quite loud headphone reception ( low-z). Coil and variable cap covers about 3.5- 3.85 Mhz. Very usable for general work. I will eventually team this up with a Michigan mighty-mite. A two-transistor ham station.
I found that Radio Shack phones # 3300088 are cheap and much much more sensitive and louder than most other cheap phones. Going through a radio shack 1k to 8ohm transformer ( they still carry it). I also made a one-turn variometer for the tickler. With a variometer, you can eliminate the need for two parts, the usual pot or variable capacitor, and the large and bulky choke.
 Post subject: Re: One FET Regen
PostPosted: Mar Tue 11, 2014 12:16 pm
That looks great to me. Do you have a schematic for this rig. I just might try it myself.
sitn 8)
"Don't find a fault, find a remedy" Henry Ford
Member:TCA
Member: Radiomuseum
PostPosted: Mar Tue 11, 2014 4:53 pm
Nice work.
I love that vernier drive... looks like it could be used to crank an old Ford starter! Is that WW II vintage?
PS: With a name like "J310" you must really like JFETs?
PostPosted: Mar Tue 11, 2014 10:46 pm
sitn 8)
Yes, I will draw one later this evening and post it. Check back later to have a look. :)
PostPosted: Mar Tue 11, 2014 10:49 pm
Rich, W3HWJ wrote:
Nice work.
I think the knob is WW2 era, but the vernier/variable cap unit I picked up at a hamfest. It has a ball vernier built into the shaft, then the brass gears slow it down some more. A little more than 8 turns stop to stop. It says its made in England, but I dont know what it was for originally , I wish I would stumble across some more!
I love FET's you guessed it. :)
PostPosted: Mar Wed 12, 2014 1:30 am
Ok, here is the schematic. Ill gladly answer any questions.
PostPosted: Mar Wed 12, 2014 2:10 am
Thanks for the schematic. I think I can weed my way through it.
sitn 8)
Member:TCA
Member: Radiomuseum
PostPosted: Mar Wed 12, 2014 3:33 am
Interesting approach to the JFET bias. Doe the LED pull enough current to light?
English verniers used to come from Jackson Bros.
http://jlkolb.cts.com/site/vernier.htm
PostPosted: Mar Wed 12, 2014 10:46 am
Yes, the LED lights and gets brighter when it goes into oscillation.
From that link, the picture in the lower left corner looks the most like the vernier/capacitor drive I have.
PostPosted: Mar Wed 12, 2014 2:57 pm
Have you tried a bypass capacitor with the LED? Does it make a difference?
PostPosted: Mar Wed 12, 2014 9:23 pm
I tried a .01 and a 10uf capacitor as a bypass. It made very little to no difference. The LED does a good job at bypassing RF and audio while setting the bias......
I also tried red and green LEDs and the green ones seem really close to optimum bias. Also, I noticed many others have been 4 or 5 turns for a tickler. This is way too much feedback for an FET. Also I stick with air core coils only, no toroids. On AM you can couple more antenna into the tank, but for CW and SSB, you want very light coupling. The signal will boost itself up in oscillation mode.....With light coupling on tickler, tank, and gate cap, the Q stays high.
PostPosted: Mar Thu 13, 2014 6:03 pm
Looks like a fun radio. Interesting that you got good regeneration control with a variometer. So the vario doesn't cause much frequency shift?
PostPosted: Mar Sat 15, 2014 1:24 pm
Very little frequency shift as I used only one turn and very fine wire. And it still will oscillate hard enough to mix against stronger signals to eliminate overload.
PostPosted: Mar Mon 17, 2014 10:47 am
J310, I built the Michigan Mightymite for 40m.
http://www.nt9k.com/image/flmightymite.jpg
I think I'll dig it out and redo it for 80m and give your regen a try.
As I recall, the mightymite didn't do so well on 40m, maybe 80 will be better.
Thanks for sharing with us!
73, Bill NT9K
http://www.nt9k.com
PostPosted: Mar Mon 17, 2014 2:20 pm
Im hoping to get my MMM together sometime in the fall, I have to put radio on the back burner for a while. Your website is awesome!
PostPosted: May Tue 06, 2014 3:41 am
Hello there! New here. Been playing with crystal and simple transistor radios for many years. I also collect and restore antique radios.
Quesiton about this circuit please. How do you adjust the "variometer"? I see no adjustment on the coil or the schematic.
Thanks much!
Gabe
PostPosted: May Wed 07, 2014 3:41 am
Thanks much!
Gabe
Hi Gabe,
The single turn tickler coil is inside the tank coil on the cold end and rotates to increase/decrease regeneration. The small knob turns the shaft which I made from one of the wifes insulin syringes. The shaft passes through into the tank and rotates a smaller pill bottle form with the one turn tickler.
Also, I thought I would add that the miniature audio transformer (8ohm-1k) is a radio shack part number 273-1380
PostPosted: May Wed 14, 2014 8:58 pm
Thanks much!
Gabe
Hi Gabe,
Thanks for the reply! So in keeping consistent: pill bottle, syringe. ;-)
That's pretty nifty. I am guessing you used the plastic plunger piece?
I prefer to use a linear pot across the coil myself. Haven't played with a variable ticker coil. I have a radio kit that while uses a tickler for regen, varies the bias on the transistor. Not sure which is best.
Thanks!
Gabe
PostPosted: Oct Thu 01, 2020 2:30 am
hi
Would somebody please redesign the circuit to be a simple RF Amplifier to use for retrofitting antique radios?
thanx
73 de jordan ve7jjd
jjdobrikin@gmail.com
PostPosted: Oct Thu 01, 2020 3:13 am
http://www.techlib.com/electronics/crys ... FAmplifier
Users browsing this forum: szoftveres and 6 guests
