It is currently Oct Mon 18, 2021 2:09 am
 Post subject: AM with IN4148 double balanced mixer
PostPosted: Jul Mon 26, 2021 6:29 am
Old note. Circuit was tested and worked fine. The DBM generates the sidebands and the carrier is introduced by a -16dB resistive pad feeding the emitter of the transistor buffer amplifier. The AM generated was high fidelity and 100% modulation was obtained. Output power was low. A 5 feet of wire acted as an antenna and the signal covered my small room. Transistor buffer current = 5ma (< 100mW DC). Ft of C3199 is 100MHz. A 2n2222 will work just fine. If I remember correctly I used a BN 43 - 202 ferrite binocular core to wind the coils. This circuit is broadband and will generate AM from 500KHz to 30MHz.
Sharing FYI.
 Post subject: Re: AM with IN4148 double balanced mixer
PostPosted: Jul Mon 26, 2021 9:01 pm
Unbalance the mixer, and the carrier feeds through.
PostPosted: Jul Mon 26, 2021 9:19 pm
Yes. This ckt needed no adjustments.
Users browsing this forum: Dirt Bomb and 9 guests
