It is currently Oct Sun 24, 2021 5:21 am
 Post subject: Polyakov mixer working for DSB generation?
PostPosted: Jul Mon 26, 2021 9:47 am
Hi, I have used this Polyakov mixer and works ok on receive. However I am trying to generate DSB and I can sense no RF out of the mixer when feeding the audio signal at the low end or directly at the LOSC port. Can't this mixer be used that way to generate DSB?
 Post subject: Re: Polyakov mixer working for DSB generation?
PostPosted: Jul Tue 27, 2021 5:56 pm
Might be a better post in Home Brew section??
PostPosted: Jul Thu 29, 2021 10:16 am
Increase oscillator drive. See if it works. It won't. Try a balanced version with self biasing and a transformer.
PostPosted: Jul Thu 29, 2021 3:46 pm
Self biasing with R1, C4, C5. Now the oscillator drive need not be adjusted all the time plus it's single balanced.
PostPosted: Jul Thu 29, 2021 3:53 pm
Double balanced version. It will generate DSB.
PostPosted: Jul Thu 29, 2021 4:04 pm
You'll need opamps to combine the audio during Rx and generate 0 and 180 degree phase shift AF to drive the mixer during TX. This circuit should have excellent AM rejection and carrier suppression thanks to the transformer. Match the diodes.
PostPosted: Jul Fri 30, 2021 5:49 am
I don't think back-to-back diodes will work.
This article discusses microwave mixers, but the BASIC configurations still apply:
https://eng.libretexts.org/Bookshelves/ ... les_(Steer)/06%3A_Mixer_and_Source_Modules/6.03%3A_Single-Ended_Balanced_and_Double_Balanced_Mixers#:~:text=6.3.5%20Summary%20%20%20%20Mixer%20Type%20,m%20...%20%20%20Increasingly%20complex%20circuitry.%20
cron
