It is currently Dec Thu 09, 2021 11:30 am
 Post subject: Frequency counter
PostPosted: Sep Wed 15, 2021 4:54 pm
What would be a good frequency counter to use on my home brews? Sometimes you wait forever for a station ID. It would also be handy for ham radio signals
 Post subject: Re: Frequency counter
PostPosted: Sep Wed 15, 2021 6:06 pm
There's some really inexpensive frequency counters on eBay and Amazon that I have heard work really well.
That being said, if your primary use is with a receiver to decode what frequency is being received, there may be some more work involved.
I have heard that some regenerative radio enthusiasts can read the frequency with a counter by throwing the regenerative radio into oscillation. It would not as be as direct a process with a superhet. Years ago Radio Electronics or Ropular Electronics had a project which would give a digital readout to any superhet. It was too complicated for me then and may still be.
My brute force workaround for this is to have my trusty digital readout radio next to the analog radio that I'm listening to. I tune it to the same signal and just read the frequency on the digital radio.
PostPosted: Sep Wed 15, 2021 6:40 pm
If you are able to pull out an oscillator signal (without degrading reception) you could use one of these:
https://www.ebay.com/itm/333979789362
If there's an IF frequency, you can enter that and it'll add / subtract it from your VFO frequency.
Not knowing your specific setup, I don't know if this would suit you.
Mike Yancey, KM5Z
Dallas, Texas
PostPosted: Sep Wed 15, 2021 10:29 pm
If you want to display the actual frequency your receiver is tuned to your frequency counter must have:
1) - A presettable (+/-) offset to add (or substract) the receiver I.F frequency.
2) - High input sensitivity and impedance to be able to lock on the receiver's L.O without loading or disturbing it. (loose coupling is preferred)
Point (2) above is usually the tricky part.
PostPosted: Sep Wed 15, 2021 11:03 pm
I'd argue the first is harder, since there are lots of frequency counters, but only some intended for the purpose, that have the ability to add an offset.
A frequency counter intended for testing won't have offset.
PostPosted: Sep Thu 16, 2021 1:19 am
What type of homebew receivers do you build - TRF, Regen, Superhet, etc.? The simplest way to ID a station's frequency with a frequency counter is to measure the output of a signal generator whose frequency is set to beat against the station being received.
PostPosted: Sep Thu 16, 2021 3:23 pm
After all the answers,I think I'll just be patient and wait for station id's ! I thought you just held a probe somewhere strategic and got a reading. Thanks for the info guys.
PostPosted: Sep Thu 16, 2021 10:21 pm
Yes. Some frequency counters are sensitive enough to do that. That's what I do with my homebrew superhets. However, as already mentioned, if you're using a regen, then you'll need to increase the regeneration control to make it oscillate. Once you have your frequency reading, you can readjust the regen again for most sensitive operation.
