Author |
Dave Wise
Post subject: Re: Pioneer SX-780 turn on problem Posted: Aug Wed 26, 2015 9:13 pm |
Member |
Joined: Feb Thu 08, 2007 12:36 am Posts: 2139 Location: Hillsboro, Oregon
Dielectric grease != heat sink grease. The latter is specially formulated to fill microscopic pits and voids with material that's a good conductor of heat. It should be available anywhere you can get transistors etc that go on heat sinks.
Pioneer receivers are notorious for their pistol-hot power supply regulators. Some people relocate the big transistors to the amplifier's main heat sink. While you have the PS board out, you might as well replace the electrolytic caps, because they've been in the oven for too long. Replace with models selected for high temperature and long life, so you don't have to do it again.
Top |
Turntables-Trails-Seattle
Post subject: Re: Pioneer SX-780 turn on problem Posted: Oct Thu 31, 2019 10:01 pm |
Just wanted to say that I found this thread after experiencing the exact same issue on my SX-780. I re-soldered the 3 regulators on the board and it now works perfect. Thanks!
Top |
Barry H Bennett
Post subject: Re: Pioneer SX-780 turn on problem Posted: Dec Sat 14, 2019 10:32 pm |
Joined: Nov Wed 30, 2016 7:35 pm Posts: 5414 Location: Sunbury, Ohio 43074
I cannot even count the number of receivers that can be fixed by just two service operations. The first is a visual inspection, followed by removing and replacing the solder on any overheated joints. Typical are the aforementioned regulator and pass transistors, and a lot of the time, high wattage resistors. They just degrade the solder on the PCB over time, and sometimes even lift the foil.
The next biggie is dirty switches. Over and over again a unit comes in with "powers up but no sound" ... and turns out to be nothing more than the TAPE MON switch having oxidized enough to simply prevent any audio output. A shot of contact cleaner or D5 and she's good to go. Of course such units get every pot cleaned, shafts lubed, and the rest of the switches cleaned as well.
For the other 25% of the units..... some can be extremely painful to fix. Surprisingly few bad electrolytics however. Should they all be replaced ? Probably but... the intent here is to "just fix the unit". If someone wants one fully restored, I pass. One cannot charge enough to replace every electrolytic in an old Pioneer, or even a Marantz, if you have to charge for your time.
And as far as the protection relay, I have also seen a few of these that have intermittent contacts or don't make contact at all. Depends on how long the thing has been sitting unused.
_________________ Preserving the hist. of electronics, one boat anchor at a time! :) https://www.bbtvtestequipment.com
Top |
Who is online |
Users browsing this forum: Google Adsense [Bot] and 4 guests |
