It is currently May Fri 29, 2020 5:23 am
Post New Topic Post Reply  [ 46 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Heathkit W-5M amplifier rebuild
PostPosted: Mar Mon 12, 2018 3:55 am
The original laminations have nickel in them , which helps with the frequency response .
Mark
Mark
PostPosted: Mar Sat 28, 2020 11:29 pm
I know this is an old thread but I am using the same output transformer as you did in my w5m and I had an oscillation when I put it together I disconnected the 16 ohm tap and it whet away I saw the only change you ended up making was to change the 270 ohm resistors between the screen taps and the screens of the KT-66s with 1K resistors I was just checking those resistors and one of mine was fried should I replace them with 1k resistors thanks for any help
PostPosted: Mar Sun 29, 2020 10:33 am
Reverse the plate connections along with the screen connections ( the phase of the replacement transfomer is opposite f the original ) causing it to oscillate .
Yes change the 270 ohms to 1K .
Mark
PostPosted: Mar Tue 31, 2020 3:46 am
Thank you I will try this as soon as I can get my hands on those resistors
PostPosted: Apr Tue 07, 2020 5:35 pm
That did it everything is working now
PostPosted: Apr Tue 07, 2020 6:12 pm
Glad to help out .
Mark
Users browsing this forum: Google [Bot] and 8 guests
