It is currently Mar Tue 31, 2020 11:45 pm
 Post subject: Wire help
PostPosted: Aug Fri 16, 2019 7:33 pm
Hello All,
been searching around forum but haven't been able to find what im looking for.
My brother-in-law gave me this very nice antique radio and vinyl player. unfortuantley wires werent included and i don't know what type of connectors these are, can someone help identify and possibly link me to where i can purchase wires.
i need to connect the speakers.
below is the best picture i could get for now.
please let me know
all help is appreciated.
Thank you,
Carmine
 Post subject: Re: Wire help
PostPosted: Aug Sat 17, 2019 3:29 am
Get on Amazon and look for 5 pin DIN (Dual In Line) to RCA
As for the speaker connections, those will have to be completely rebuilt. You will need a meter to measure ground and positive.
Also, if this is a tube amp, it will need to be electronically serviced before put in regular use. THIS MUST BE DONE.
PostPosted: Aug Sat 17, 2019 3:48 pm
Here is an example of what you need (although mine only has three pins):
Male Din plug to either female (as mine is-if your record changer or tape deck has male plugs already) or male RCA type plugs.
I can't make out the speaker plug in your pic to give any advice.
+1 to MUST be gone over before using.
Dan
PostPosted: Aug Sat 17, 2019 10:09 pm
Artcurus wrote:
DIN (Dual In Line) .
A DIN connector is an electrical connector that was originally standardized in the early 1970s by the Deutsches Institut für Normung (DIN), the German national standards organization.
Eddy
PostPosted: Aug Sat 17, 2019 11:18 pm
Your speaker plugs are available from JAYCAR.
https://www.jaycar.com.au/
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Aug Mon 19, 2019 3:58 pm
thanks everybody, help is much appreciated.
will try to purchase the wire and report back.
cron
