It is currently Jun Thu 04, 2020 7:16 pm
 Post subject: Don McGohan MG-10B Replacement Power Transformer
PostPosted: Aug Wed 07, 2019 3:51 am
I picked this up at an auction so I don't know much about it.
I started looking it over and got a copy of the Sam's Photofact (Set 190 folder 8).
Someone in the past has replaced the power transformer. The power transformer currently installed is rated for 550v CT. It is a Triad R-12A. The parts list calls for a 650v CT transformer. The amplifier is designed for 6V6 output tubes.
My question is what will the 100 volt difference make in the output and sound of the amplifier? Should I track down a better power transformer?
My Blog: http://ckpspot.blogspot.com
 Post subject: Re: Don McGohan MG-10B Replacement Power Transformer
PostPosted: Aug Wed 07, 2019 2:18 pm
Really 50V difference, 275-0-275 vs 325-0-325. If it has a tube rectifier, you can get a good part of that back by replacing it with a pair of diodes (1N4007 will do).
Maximum undistorted output will be less with lower voltage. It's possible that some resistors were changed to make up some of the difference.
PostPosted: Aug Mon 12, 2019 1:33 pm
If it uses a 5v tube rectifier you can replace it with a 5AR4 and gain some voltage, the wiring may need some changes depending on what the original is.
PostPosted: Aug Tue 13, 2019 5:14 pm
Thanks for the advice! I have just finished replacing all the electrolytic capacitors. The amp is nice and quiet (minimal hum). I did some voltage checks coming out of the rectifier tube. I substituted a 5R4 (it is all I had). I had about 320 B+ before the first filter capacitor.
Both the 6V6 tubes as well as the 6SC7 are weak. Once I replace those three tubes I will check the sound quality and figure out a plan on voltage.
Thanks again for the advice!
PostPosted: Aug Mon 19, 2019 9:07 pm
My guess is that you will be fine with the PT "as is" and new 6V6's. Most listening is at less than 1/2 watt average, but, of course, decent "power headroom" is good to have.
5AR4's are getting pricey, but it would get you a few extra B+ volts, as Lou said. They are "plug and play" with virtually all the common 5 v rectifiers, but not the 5Y4.
Cheers.
Roger
Roger Jones,
Thornhill, Ontario
Users browsing this forum: stevebyan and 9 guests
