It is currently Oct Thu 01, 2020 5:14 pm
 Post subject: Scott Stereomaster 386 AM/FM Receiver
PostPosted: Oct Wed 09, 2019 5:35 am
Could someone help me understand why the Signal Strength Meter will not change at all when scanning AM or FM stations. However, the meter will swing to the right when the receiver is turned on. R603, a 5K pot in line will move the meter full scale either way, but wherever the meter is left, it will just stay there and not respond to the AM or FM signal changes. If you power down, the meter will go back to the left. I'm not a super techie, but am OK at it. I'm not sure where to start troubleshooting. (See attached)
The unit has excellent Sensitivity and Selectivity on both bands and works well.
Thank You
File comment: Portion of schematic showing S Meter in circuit.
 Post subject: Re: Scott Stereomaster 386 AM/FM Receiver
PostPosted: Oct Thu 10, 2019 12:44 am
You need to find a schematic with more detail, the circuit of the IF AMP board is probably where the problem is.
Tim
PostPosted: Oct Thu 10, 2019 12:59 am
Thank You, I will review the Service Manual better.
PostPosted: Oct Thu 10, 2019 4:01 am
I was able to locate the HH Scott 386 Schematic
File comment: Scott 386 Schematic
Scott-386-Schematic.pdf [481.91 KiB]
Downloaded 104 times
PostPosted: Oct Thu 10, 2019 7:16 am
Back around 50 years ago, I remember having much trouble with black plastic cased single-ended axial electrolytic capacitors in Scott products. Their failures were often intermittent. When I could focus the problem to a single circuit card, I would replace all the black caps on that card. New caps were cheaper than my time.
-Chuck K7MCG
PostPosted: Oct Thu 10, 2019 2:39 pm
What is needed is a detailed schematic of the IF amp circuit board (part # 100-1331-013). The Scott service manual will have this. What you have shown in your PDF is a connection diagram for the unit's circuit boards.
PostPosted: Oct Thu 10, 2019 4:13 pm
Manual attached
Thank you
Scott-386-Service-Manual.pdf [6.99 MiB]
Downloaded 113 times
PostPosted: Oct Fri 11, 2019 2:20 am
Some schematics in the manual you provided were poorly scanned and this is one of them. But it is good enough to get an idea of the meter driver circuit. I would first check the condition the diodes in the circuit and the associated cap going to ground. Arrow is pointing to the meter output connection.
File comment: Click to Enlarge
PostPosted: Oct Fri 11, 2019 2:37 am
Thank You Dave, I will look into it when I retun in a few days.
Thankfully, I was also able to procure an original Service Manual beyond that scanned copy.
Have a great weekend!
PostPosted: Oct Sat 26, 2019 5:51 am
Hi Dave
I went throught the diodes, cap and resistor on that meter circuit and all are fine. But, that test point where you have the arrow shows 1.18 volts (noise) there. I'm only getting .25 volts regardless if I am on a strong signal or just noise. It doesn't matter if I am on AM or FM, same problem.
Any idea where I should look next?
Users browsing this forum: 45 Nut and 10 guests
