Can you help me identify this amp so I can get a schematic for it. It is marked 7621 1. Also has a small sticker that says 311. It has 3 tubes- one 12ax7 and two 50c5. I was told it came from a zenith phono
Be careful. This is a hot chassis, powered by line voltage directly. You should add an isolation transformer to protect any equipment you intend to plug into this amp.
