It is currently Sep Mon 20, 2021 12:22 pm
 Post subject: FOUND. dial belt and dial lamp bulbs
PostPosted: Jun Mon 28, 2021 6:12 pm
Need dial belt for Zenith 26-298. Looking for a new continuous belt not a cut an glue type. Also looking for a 4 lamp bulbs for the same radio. Thank You
Thank You for your responses because of your help I have found the items
 Post subject: Re: WTB dial belt and dial lamp bulbs
PostPosted: Jun Mon 28, 2021 6:32 pm
Try the Quality Radio Belts ad in the right column. He does a great job... and reasonable.
- George Kaczowka - (K and Mumble a bit)
- http://www.oldradios.com (george@)
PostPosted: Jun Mon 28, 2021 9:13 pm
Is your radio a 10-tube set with black pushbuttons?
From Quality Radio Belts, order the belt for model 10-S-669. The dial lamp is either type 44 (if they are bayonet) or 46 (if screw-in) miniature lamps, and those can be bought anywhere online.
PostPosted: Jun Mon 28, 2021 11:43 pm
In my Zenith 9S-262 I replaced the dial belt with a large "O" ring. My mistake wad using a small diameter O ring but it works fine after almost 20 years. I did not cut/glue it, I took apart the shutter dial to install it.
Sal
Need capacitors, resistors and other parts--> http://www.tuberadios.com/capacitors
PostPosted: Jun Tue 29, 2021 1:39 am
Thank You
Post New Topic Post Reply  [ 5 posts ]  Moderators: Alan Voorhees, Philco Fan
Users browsing this forum: Avery, processhead and 8 guests
