Author |
Rich, W3HWJ
Post subject: Fetron Posted: Sep Sun 25, 2011 8:17 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 11378 Location: Santa Rosa, CA
Top |
Johnnysan
Post subject: Re: Fetron Posted: Sep Sun 25, 2011 9:56 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 16795 Location: Albuquerque, NM 87123
They destroyed a 12AT7 just to take a picture!
What a bunch of idiots!
Top |
easyrider8
Post subject: Re: Fetron Posted: Sep Mon 26, 2011 4:58 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 10748 Location: Mpls, Minnesota
Top |
jimihendrix
Post subject: Re: Fetron Posted: Jan Tue 24, 2012 9:10 pm |
When that article was written the valve (sorry tube) would have cost about $1.5 in the U.K.
Top |
threeneurons
Post subject: Re: Fetron Posted: Jan Tue 24, 2012 10:27 pm |
Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 4571 Location: Tehachapi, CA - Bottom end of the Sierras
Not quite a drop-in replacement. If some piece of gear had the heaters in series, this could cause a problem. At least a little rewiring needed. The 1st page of the PDF article states power savings due to no filament, not even as a resistive dummy path. But that would mean heat, which transistors don't like. Even in 1972, this doesn't sound like a bright idea. Everybody pretty much new by then, that tubes were on their way out. The exception being some very niche areas. The article does mention their use in telecom installations. I would have hoped Teledyne had a big order, to justify developing and making them. And they were just trying to make a little extra gravy by selling them elsewhere. Has anybody run across these, in an actual piece of gear ? I've come across SS rectifier replacements, but never an amplifying tube substitute. If you get one make something new with them, and also use a nuvistor, or two. Transistors that look like tubes, with tubes that look like transistors.
_________________ Life is like a roll of toilet paper - The closer you get the end, the faster it goes - A.E. Neuman
Top |
Norm Leal
Post subject: Re: Fetron Posted: Jan Tue 24, 2012 10:33 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 30905 Location: Livermore, CA
I received some from a person who worked for the company. Never saw Fetrons used in equipment.
_________________ Norm
Top |
markjd
Post subject: Re: Fetron Posted: Jan Tue 24, 2012 11:10 pm |
Member |
Joined: Mar Tue 02, 2010 6:53 pm Posts: 299 Location: Virginia
Top |
Rich, W3HWJ
Post subject: Re: Fetron Posted: Jan Tue 24, 2012 11:28 pm |
If I remember rightly, Western Electric wanted them to replace 6AK5s.
Never saw one in equipment.
We talked about it at Siliconix in the late 80s, but never saw any real need for it. Too many circuit variations to make a general replacement for any particular tube.
Top |
Braithwaite
Post subject: Re: Fetron Posted: Jan Wed 25, 2012 1:13 am |
Joined: Nov Sun 04, 2007 6:01 am Posts: 4028 Location: Redding, CA
I have a complete unused Teledyne HP400D/H/L-5 fetron conversion kit for partial conversion of the HP 400D VTVM to a SSVTVM. It consists of five fetrons to replace the five 6CB6 tubes in the HP 400D, H, L, and ME-30A/U, B/U, and C/U. It is dated 1974, starts out "Conversion is simple" and includes 12 pages of recalibration instructions and service data. Apparently, the instructions discouraged the buyer of this kit from proceeding with the simple conversion.
Norman
_________________ "No home is complete without music" - Capehart Sound Amplifying and Distributing Systems
Top |
steve rosenfeld
Post subject: Re: Fetron Posted: Jan Wed 25, 2012 11:51 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1118 Location: forked river , n.j. , usa
used them to replace 403-b tubes in v-3 repeaters.never had a problem with them.set the gain on the amps & never had to readjust.maybe 40 of the amps were in use with the fetrons for 10 or so years.only reason they wern't used longer was the system was replaced with t-carrier when fiber replaced the copper pair cable . steve
Top |
Rich, W3HWJ
Post subject: Re: Fetron Posted: Jan Thu 26, 2012 12:14 am |
Quote: used them to replace 403-b tubes I was close, but not exact. 403-B was the AT&T / W.E. version of the 6AK5. Rich
Top |
Jim Cross
Post subject: Re: Fetron Posted: Jan Thu 26, 2012 2:12 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1521 Location: Orlando, FL, USA
Western Electric called their fetrons "hybrid integrated networks" or HINs. They made at least five different types, but each type was designed for a specific location in a specific piece of equipment. I think at lease three of the 5 are 403A variants.
Jim Cross
Top |
steve rosenfeld
Post subject: Re: Fetron Posted: Jan Thu 26, 2012 3:25 am |
you're right about the name HIN's they has a KS- spec number also. used them in the LD-T2 transmitters where there were 403-b tubes. they worked ok in that application too.rf didn't seem to cause any problems. steve
Top |
Rich, W3HWJ
Post subject: Re: Fetron Posted: Jan Thu 26, 2012 3:45 am |
Quote: Western Electric called their fetrons "hybrid integrated networks" or HINs. They made at least five different types, Did WE actually make these, or buy them from Teledyne or some other JFET maker? Rich
Top |
Jim Cross
Post subject: Re: Fetron Posted: Jan Thu 26, 2012 4:52 am |
I do not know the answer absolutely, but sine they did make their own transistors, I am inclined to think they made these too.
Jim Cross
Top |
Norm Leal
Post subject: Re: Fetron Posted: Jan Thu 26, 2012 4:26 pm |
Teledyne made at least 14 versions of 407A and 17 versions of 408A. Looks like they couldn't use one Fetron to replace a tube in any circuit. They started assigning Fetron numbers with TR1000. The highest number I show is TR1095 and between those numbers only cover about a dozen tubes. They even made a Fetron, TR1010, for 2D21 thyratron.
Top |
Braithwaite
Post subject: Re: Fetron Posted: Jan Thu 26, 2012 6:36 pm |
Norm:
The HP400D/H/L-5 kit includes a TR1098 to replace one a 6CB6 tube in one application.
Norman
Top |
Burnt Fingers
Post subject: Re: Fetron Posted: Jan Sun 29, 2012 11:38 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 11481 Location: Southern NH, 03076
There were kits offered for the Collins S Line as well as some Drake gear. As with any SS back then what you gained in sensitivity you lost in overload handling. When used in other stages they did OK and reduced heat.
Top |
wb0ldj
Post subject: Re: Fetron Posted: May Sun 22, 2022 3:15 am |
Joined: Jul Mon 15, 2013 12:25 am Posts: 6 Location: St. Louis, MO
I stumbled upon this topic when Googling. Actually, I have a Heathkit IM-28 bench VTVM that I'm using Fetrons in. The 6AL5 is a TR-1002 (Heathkit # 150-57), and the 12AU7 is a TR-1119 (Heathkit # 150-58). I've had them installed for years and the meter calibrates and functions perfectly, just like it had the original tubes installed. I have also added a power supply to replace the 1.5V "D" cell ohms battery. Everything works great.
However, I've never seen another "set" of Fetrons on EBay or elsewhere. Mike Harmon, WB0LDJ
Top |
mblack
Post subject: Re: Fetron Posted: May Sun 22, 2022 3:53 pm |
Joined: Jun Sun 15, 2014 5:37 pm Posts: 2030 Location: Montreal, Quebec
Solid state "tubes" at least commercial products, targetted a few specific tubes. So if you could replace the tubes in telephone equipment, the "tubes" would last longer, and you'd reduce heat inthe equipment, so other components might have longer life.
But it was a brief period, keep tube gear running a bit longer. Once the tube gear was replaced, no more Fetrons and the like needed.
There was also a letter, in Ham Radio or QST, from someone who noted they weren't perfect. Something like the "6AK5s" were good as limiters in FM receivers, but didn't do agc well. I may be remembering the details wrong.
Hams did tube replacement in various ways. General plug in replacements, not sure how well those worked. Sculpting to the stage, but trying to keep the existing circuitry intact. Changing existing values as needed. Or start almost from scratch, using the equipment as a foundation and basically each stage new. An example of tye last was in Ham Radio for Feb 1969, Hank Cross converts a BC-348 and makes it better
Top |
Users browsing this forum: edison and 14 guests |
