It is currently May Sun 31, 2020 10:44 pm
 Post subject: 25Z4 tube settings for Eico or Knight testers
PostPosted: Jan Mon 16, 2017 5:07 am
Hello
Anyone have the settings for a 25Z4 tube. I have an Eico 666 and a knight 520. I believe the 600 series settings will work as well. Nothing on the roll charts or Bama site. Thanks!
Rod
 Post subject: Re: 25Z4 tube settings for Eico or Knight testers
PostPosted: Jan Mon 16, 2017 6:26 am
Rod
Use 35Z4 and reduce filament voltage from 35 to 25 volts.
PostPosted: Jan Mon 16, 2017 6:44 pm
How stupid am I! Thanks Norm.
PostPosted: Jan Mon 16, 2017 6:49 pm
What do you have that uses a 25Z4??? on the grille cloth site there are only three sets listed and without doubt, two of those are incorrect...
PostPosted: Jan Mon 16, 2017 7:22 pm
Here is the radio.
http://www.radiomuseum.org/r/portadyne_portadyne_table_model_2.html
I can't find a schematic for it anywhere and can't even confirm it's model designation but mine looks identical to the one pictured. I picked it and another French one up that I can't identify.
Rod
PostPosted: Jan Mon 16, 2017 7:29 pm
Rod
Use settings for 35Z4 except for filament, as mentioned, to test the 25Z4. Do not attempt to use a 35Z4 in your radio as it has different filament current. Tube filaments are wired in series in your radio. All tubes must have the same current rating when used in this radio.
For information on your radio might try Paul Stenning's UK forum:
http://www.vintage-radio.net/forum/index.php
PostPosted: Jan Mon 16, 2017 8:35 pm
Interesting...
Note the radio pictured on the RM site may be using a full wave rectifier, at least it appears to have two plate structures...
PostPosted: Jan Mon 16, 2017 8:41 pm
Wonder if it's a 25Z6? That tube was commonly used with the others..
PostPosted: Jan Mon 16, 2017 9:19 pm
The tube marking is gone on one and all I can make out is 25 and 6. I'm assuming it's the 25a6 which failed on that setting on my Eico. Has a good rattle inside it as well. I'm using the tube lineup in the radio in radiomuseum as the others look to be correct. The two 6k8's have 6a8's in place but my understanding is that they are interchangeable. The 6q7 is in place as well as the 25z4. I used the 35z4 settings with 25 v filiment selected which showed a short as soon as I plugged it in the socket. I'll grab a few tubes and go from there. Thanks for the help!
Rod
PostPosted: Jan Mon 16, 2017 10:07 pm
Yes I was thinking same... Would be easy enough to use the Z6, as long as the are no connections on the socket to pins 3&4 would be a direct swap... Or it's easy enough to clip those pins and make it electrically same as a 25Z4...
PostPosted: Jan Tue 17, 2017 8:12 pm
Sure wish I had a schematic for this thing! In looking at the connections, pin 1 is unused. Pin 2 and 3 have one side of the line cord attached. Pin 4 goes to filter cap and is also bridged to pin 8. Pin 5 and 6 are unused and 7 goes to pin 2 of the 25A6. Should I be able to drop a 25z6 in this?
PostPosted: Jan Tue 17, 2017 8:31 pm
As long as pin #5 is unused you can use a 25Z6 tube. Pin #5 is the second plate. For more available current best if it was connected to pin #3.
PostPosted: Jan Tue 17, 2017 9:08 pm
Thanks for that. Looks like I have another issue. I didn't catch on to this right away but have a look at this coil.
https://goo.gl/photos/yYi5cvB9q6hmRj7m6
Salvageable? What could be possible causes?
Rod
PostPosted: Jan Tue 17, 2017 9:40 pm
Rod
This is most likely the antenna coil? If so lightening might have caused wire to burn and unwind? If that is a non tuned section of the coil you could rewind the bad part. Exact number of turns is critical unless it's tuned.
AES, http://www.tubesandmore.com and Radio Daze, http://www.radiodaze.com both sell universal antenna coils. Problem being coil is only for broadcast band, not short wave.
PTOP may have a replacement but the list is long.
http://www.oldradioparts.com/2a6fla.txt
PostPosted: Jan Tue 17, 2017 9:46 pm
Great, thank you very much. I'll see what happens with replacement tubes and go from there.
Rod
