It is currently Oct Thu 17, 2019 2:24 am
Post New Topic Post Reply  [ 1 post ]
 Post subject: Sealed can-style tuning & osc coil ID?
PostPosted: Feb Fri 23, 2018 3:33 am
I'm slowly working my way through drawing out the schematic of this cursed early 40's US Philips - a 6 valve "AA6"-like design with local / DX BCB & 2 SW bands - and I'm on the last (& hardest) leg: the band switching and sealed tuning & oscillator coils.
This is the oscillator can from the top of the chassis. It's labelled "13-332" and "69 CHASSIS FINAL":
And this is the RF tuning coil can from the bottom - in the first pic it's the can under the mezzanine that holds the antenna coupler & 12SK7/6SS7 RF amp:
There's a total of 12 connections laid out like this:
Code:
with "|" being solder tags & * being flying wires. The 12th connection is another flying wire from the anode of the RF amp that enters through a hole in the top.
The osc can pinout is almost identical except it only has 10 connections - just 1 flying wire at the bottom and no top wire.
Since all the other original bits of this radio are standard US parts - Stancor power & output transformers, C-D caps, etc- I'm hoping that these cans are too, and that someone recognises them and can suggest likely pinouts (or, dare I hope, point to a datasheet? ;))
Otherwise I'm going to have to try and nut it all out and probably end up having to pull at least one of them to open & see. I'd rather not do that, since the oscillator can is right under the front of the dual-wafer bandswitch & the tuning coil can requires removing the mezzanine (and is screwed to it from inside the can, so I-don't-know-it's-all-a-bit-chicken-and-egg...)
Rod.
Users browsing this forum: Rod FeC and 5 guests
