It is currently Feb Fri 28, 2020 7:14 pm
 Post subject: Philco 38-3 power transformer
PostPosted: May Mon 20, 2019 8:17 pm
The secondary high voltage winding is open I am working
on the voltage and current ratings for a replacement. Does anyone have any suggestions
 Post subject: Re: Philco 38-3 power transformer
PostPosted: May Mon 20, 2019 8:44 pm
That doesn't seem to be a good model number. What are the tubes in the radio?
Jay
PostPosted: May Mon 20, 2019 10:09 pm
http://www.nostalgiaair.org/Resources/243/M0013243.htm
Terry
PostPosted: May Tue 21, 2019 2:20 am
Terry,
Thanks, I forgot that it might be the chassis number instead of a radio model number.
Assuming that it is a 9 tube, triple chassis, radio, the high voltage winding needs to produce 330VDC at about 120mA.
If the transformer is rated for the DC output at the rectifier, the requirements are above.
If the transformer is rated for AC output, the 5Y4 curves show that it requires 325VAC on each plate to get 330VDC output at 120mA.
The RMS current rating for the high voltage winding will need to be at least 180mA.
Jay
PostPosted: May Wed 22, 2019 2:14 pm
Thanks to JhTX for your post it will help a lot.
A came up with a Hammond 273DZ horiz. mount
it might be a little low on the current rating.
I will go back and research again and see what I can find.
thanks a million guys
George Kirk
Caseyville Illinois
