It is currently Jun Wed 19, 2019 1:49 am
 Post subject: Part Identification and Capacitor question
PostPosted: May Sat 11, 2019 8:21 pm
I attached 2 files, one is of a round ? and the other is a capacitor. Both are from a ROBYN T-123B Transceiver
1) what is this round thing is this a diode and if so what would replace it?
2) Can this capacitor be replaced with an Aluminum Electrolytic? What is WV and the (M)
File comment: what is this?
 Post subject: Re: Part Identification and Capacitor question
PostPosted: May Sat 11, 2019 8:56 pm
You can edit your original post to add the missing photo.
Or just "reply" to the original post, and include the photo in the reply.
It is best not to create multiple threads about the same project. The moderators may come after us...
The small blob on a wire thing is a diode.
Best to try to find documentation for your radio that specifies what it should be. If you know of information available online, it would be good to post links.
Does the blob have anything printed on it?
What are the diameters of the blob and of the lead wires. These can be matched up with old catalog information to get an idea about what the current or power rating was for the original part. I think such diodes were documented in the old GE Silver databook.
If you cannot locate any information, probably a 1A 1000V rectifier diode might be safe to use.
It would be good to try to discover why it blew-up, before replacing it and turning on the power.
Ted
PostPosted: May Sat 11, 2019 9:26 pm
Thank you! I thought about adding to the original post after creating the second and when I went back to delete it I couldn’t find a delete post. My mistake as I never posted a pic on here. Live and learn.
The diode dint blow it looks like it broke, if I hold it on there it makes a little spark and the radio works. I checked voltage on it and it seems to be 558vdc.
I found the schematic but can’t find the diodes in it (2ea) that I can see.
PostPosted: May Sat 11, 2019 10:16 pm
Found it! Thank you.
PostPosted: May Sun 12, 2019 5:01 am
Some of those guys have a weld just outside the body, where the special alloy bonded to the die is welded to a softer lead wire material. Probably the weld broke.
If the voltage is that high, you may need a really HV rated part. It would help to have a look at the circuit.
Ted
PostPosted: May Sun 12, 2019 8:37 pm
In answer to the next question, the capacitor in the picture is 0.1-uF, 600-VDC. It looks like it may be a paper in oil type. If so, it may be leaky enough at this point in time to be questionable. You will not find any electrolytics with those ratings. Determining a substitute would best be done knowing where it is in the circuit, but just about any modern polypropylene or polyester film capacitor of the same ratings should be able to handle it.
Thomas A. Edison
