It is currently Mar Tue 31, 2020 8:54 am
 Post subject: octal equivelent to a 12AT7 tube?
PostPosted: Jun Fri 21, 2019 8:03 pm
I need a high mu octal, single triode to go along with my 12j5gt triode, to replace the 12AT7, 9-pin tube. I am going to use 2 single triodes rather than a duo triode. I think the 12sf5gt would be ok, but I really hate to change the filiment wiring for the 12sf5gt{pins 7 and 8}from my present{pins 2 and 7} I plan to use the single triode as a grounded grid rf amplifier tube.I will use a 12j5gt,which I already have on hand, as a detector tube. Any help appreciated!...... William
 Post subject: Re: octal equivelent to a 12AT7 tube?
PostPosted: Jun Sat 22, 2019 1:55 am
The 12F5 is same tube as 12SF5 but has a top cap.
12SL7GT is a duo triode, has heater on 7 & 8.
PostPosted: Jun Sat 22, 2019 2:15 am
You might have trouble depending on the frequency you are interested in. The 12AT7 is intended for VHF use while most octal tubes are for much lower frequencies. There are a few VHF octal tubes like the HY615 but I don't know without looking it up how close that is to a 12AT7.
Jim Mueller
PostPosted: Jun Sat 22, 2019 3:33 pm
Might you use a Loktal tube? There were several VHF Loktals.
Ted
PostPosted: Jun Sat 22, 2019 6:28 pm
I know it doesn't help being that it is not a triode, but the WE-717A which was used mostly in WWII, but was also used in the consumer market such as the FM converter sold by E. H. Scott.
It is a 6AK5 VHF amplifier pentode in Octal form.
It may have been a Western Electric design, but most were manufactured by Raytheon or Tung-Sol.
It is not a tube prized by the Western Electric crazies. :lol:
PostPosted: Jun Sat 22, 2019 9:56 pm
High mu would be 12sc7, or lower 12sl7.
PostPosted: Jun Sun 23, 2019 3:38 am
No one has asked what frequencies you want to receive. Granted, a grounded grid amplifier implies higher frequencies, but is this true? The expected frequency range you plan to amplify will help determine the tube that can be successfully substituted.
― R. A. Heinlein
PostPosted: Jul Tue 09, 2019 10:12 pm
Have you considered the Loktal 7F8? It was used in some early FM and television sets, by Colonial and Philco.
PostPosted: Jul Sat 13, 2019 8:07 am
E1148
Cheap $6. tube depot. And just think how strange it would look. Good to 300 mHz.
Did I mention I have 100 of them. :D (to be crushed as a coffin liner)
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
