It is currently Apr Thu 02, 2020 1:05 pm
 Post subject: Help finding replacement speaker
PostPosted: Jul Wed 31, 2019 6:49 pm
Hello Antique Radios!
I am in the process of fixing my sylvania exponent 4/40 record player. I just located a replacement cartridge which Im excited about installing.
I also noticed that one of the speakers didn't work, I was wondering what would be a good replacement speaker to get.
Any help will be much appreciated. I attached a picture of the old one which has several numbers on it.
Thanks!
 Post subject: Re: Help finding replacement speaker
PostPosted: Jul Wed 31, 2019 9:22 pm
Speakers rarely fail!
Duct-tape two short leads to a 1.5V battery - touch their ends to the speaker terminals.
You should hear a click when you make and break the connection.
(when testing any speaker in circuit)→ If there is no click, remove speaker and test again.
Be careful of the bare ends - - - do not short-circuit the battery.
Speaker/s specifications are not listed in the factory service manual!
Service information was published in Sams Photofact Set-892 Folder-7
ref: https://www.samswebsite.com/en/photofac ... h&s=Search
Three pages of service information for Amplifier Chassis P06-5 used in model Exp. 4/40-2
can be found in this comprehensive 1966 Sylvania service manual.
It's a 162MB download!
http://www.vintagesylvania.net/?page=do ... 0Hi-Fi.pdf
Checkout your NP (non polarized) capacitors C124 and C224 on the crossover boards.
5.0μF (microfarad) is an old value - use 4.7μF as a replacement today.
25V or 35V or 50V rated replacements are okay... :)
Here is a typical Magnavox crossover board with ferrite chokes.
Your P06-5 crossovers highlighted below.
Edit: oh... I've just noticed the the total impedance for each set of sperkers is listed on the schematic as...
Total impedance 8Ω
PostPosted: Jul Wed 31, 2019 9:47 pm
Roll-your-own non polarized capacitors.
Example: connect two 15µF or 16µF (polarized) electrolytics back-to-back to make a NP (non polarized) 8µF capacitor.
:) Greg.
