It is currently May Wed 27, 2020 4:56 pm
 Post subject: Question about Mica in trimmer caps
PostPosted: Aug Thu 01, 2019 3:25 pm
I was wondering what the composition of the mica sheets used in trimmer caps?...
I found this on Amazon, and was wondering if they would work (perhaps split?)..
https://www.amazon.com/Yootop-Insulating-Sheet-Holes-x0-003/dp/B07P24S6GX/ref=pd_sbs_60_6/130-9492790-5929664?_encoding=UTF8&pd_rd_i=B07P24S6GX&pd_rd_r=bed8e1cb-8f5b-47e0-adbb-a8aa7ead6caf&pd_rd_w=sjDW3&pd_rd_wg=KVKXX&pf_rd_p=43281256-7633-49c8-b909-7ffd7d8cb21e&pf_rd_r=81C32VZTFHA8H2MTB6TJ&psc=1&refRID=81C32VZTFHA8H2MTB6TJ
Product description
Features:
Mica Plate is mica paper with silicone resin by gluing temperature and pressed, essential Parts for repairing the microwave oven or any heater.
Heat resistant; multi-layered; transparent; acid-free; archival safe.
Specification:
Suit for: TO-3 Transistor
Material: Mica, Paper, Silicone Resin
Size : 18x22x0.09mm/ 0.71"x0.87"x0.0035"(L*W)
Hole Diameter : 3.5mm
Weight: 64g
Package Content: 200(+/-2%) x Mini Mica Insulator
If not, has anyone found a source for what is needed?
Thanks!
George
- George Kaczowka - (K and Mumble a bit)
- http://www.oldradios.com (george@)
 Post subject: Re: Question about Mica in trimmer caps
PostPosted: Aug Thu 01, 2019 3:53 pm
"Mica yourself happy!
http://shop.usamica.com/ :D
PostPosted: Aug Thu 01, 2019 6:51 pm
Paul Fix, who played North Fork's, Sherif Micah in The Rifleman TV-Western, would probably have agreed with your statement ""Mica yourself happy!".... Mica sheets are fun to play/experiment with under a PLM (Polarized Light Microscope).
Fred
PostPosted: Aug Thu 01, 2019 8:38 pm
I have successfully used TO-3 and TO-220 size transistor insulators to replace mica in trimmers.
If you can find a Kapton transistor insulator, that works also and is easier to trim or punch. https://www.distrelec.ch/en/insulation- ... p/17565054
PostPosted: Aug Thu 01, 2019 8:39 pm
Someone is selling mica sheets right now on the Classified ad section.
viewtopic.php?f=15&t=362736
PostPosted: Aug Thu 01, 2019 8:45 pm
https://www.antiqueradios.com/forums/vi ... 5&t=362736
sergneri Was giving away a few sheets. Seems the sheets are all spoken for...
PostPosted: Aug Thu 01, 2019 9:45 pm
Yes, That is what started me thinking about it.. I have a few situations where replacing the mica would probably be easier than trying to clean it, and would provide backup if some of it breaks..
I was not sure what the right material would be.. It seems that there are a couple of hybrid types, all called mica..
Thanks for any information and the links so far..
PostPosted: Aug Thu 01, 2019 10:01 pm
gkaczowka wrote:
I have a few situations where replacing the mica would probably be easier than trying to clean it...
I would just leave it alone unless I was sure that it was causing some problems. And in that case I'd try an electronic spray cleaner, the kind that doesn't leave any residue.
Users browsing this forum: 1988bluebird and 11 guests
